diffeomorphic skin Materials error
I imported gen8.1 female using diffeomorphic
The skin I used at this time was HID Suzu for Genesis 8.1 Female
However, if there is something wrong with the cycles only option in the easy import daz, the blender was completely shut down and I couldn't import it. When I used the extended principled option, it worked. However, an error pop-up window appeared
And I see a difference between Toroso and the other parts of what we see in the blender, whether it's problematic
I'm a beginner in the blender I don't know how to use the node well
Is there a way to solve this problem?
Thank you for your help.
Post edited by pigcrazy4541_5266a3f7 on
You can turn off "prune node tree" in the global settings, this should work around the bug. I'll also check this when I have some time and eventually report to Thomas.
p.s. Just tried and she works fine here I don't get any error, both bsdf and principled. You may try to update the addon.
https://bitbucket.org/Diffeomorphic/import_daz/downloads/
Thank you. It's working
Instead of converting DAZ Studio materials, have you looked at either the Humanify or Global Skin addons? They are both amazing and are native Blender materials but work with Genesis 8/8.1/9 UVs.
Yes using a native blender shader will generally deliver better results, if you don't need the skin to be the same as daz studio. Same for the other materials converted from iray.
