Anime Toons and Filatoon Shader Q&A
1141517192032
  • Gendragon3D said:
    Hello everyone! I'm at a loss of how to render for Filatoon. Understanding that if I want a realistic image, in the Render-Setting, I enable it by default in NVIDIA Iray (MDL) mode. And in the case of Filatoon, how do you render a scene to be able to save an image? Thank you very much for the little angel who can help me. ^_^
    To render a Filatoon scene, choose Viewport as the render engine. Set your render settings for a decently large size as that seems to help with how they turn out.
    666 x 302 - 49K
  • t0mg_zt0mg_z Posts: 51
    Thank you! I noticed on the Material panel, that the Vicky 9 shader has the "Receive Shadows" option disabled. Toggling it on projects the shadows you see on her.
    Also, I converted the textures of the scene to FilaToon and re-added the missing opacity maps. I also played around with the options on Tone Mapping and that's it.
    3Diva said:
    t0mg_z said:
    Playing around with this thing. Took a while to figure out how to get shadows on her skin:
    That looks great! Care to share how you did it? laugh
  • 3Diva3Diva Posts: 12,058
    Ahhh I see - Recieve Shadows, that makes a HUGE difference in scenes like this. Thank you!
  • TaozTaoz Posts: 10,341
    edited October 2024
    @3Diva You can also enable shadows for the lights, here an example using the distant light.  Unfortunately you can't adjust Intensity and Softness, but hopefully that will come later.
    https://app.screencast.com/9mS97tugitb3X
    Post edited by Taoz on
    I'm in the middle of a lengthy simulation right now, but I'm pretty sure that there are shadow intensity adjustments on the individual FilaToon shaders (?) - there or in the Filament Draw Options
  • vrba79vrba79 Posts: 1,548
    We need to update the FAQ thread with all these techniques and new info.
    edited October 2024
    Yes, you're right:
    https://app.screencast.com/hUHQyD7PFxfli
    And you need to have the light's Shadow Type set to Deep Shadow Map for it to work, and Receiving Shadows must be On.
  • y3kmany3kman Posts: 875
    Which is the best truck-kun product I can use in my anime renders?
  • GordigGordig Posts: 10,785
    The Daz store is nothing but swirlies for me right now, but Predatron Light Truck.
  • crosswindcrosswind Posts: 10,220
    Except for 3djoji's Toon Truck, in fact every truck product can be converted with Filatoon ~ and reshape them a bit, to make them more toony style.
  • osterberg said:
    Hello, maybe you can help me...
    Loading Vicky 9 I have missing files:
    /data/DAZ 3D/Built-in Content/FilaToon-Base.dsf and
    /data/DAZ 3D/Built-in Content/FilaToon-Outline.dsf
    I work with DAZ 4.23
    Greetings from germany
    Martina
    Hast du alle neuen Packs installiert? Ich habe es am Anfang auch übersehen. Es gibt zB eine file im Install Manager die heißt "Genesis 9 Toon Starter Essentials 3of 3"
    Can you please tell me where to find the "Receive Shadows" option?
  • Hello, I have some questions. Can you explain what exactly the LUT and the MatCap is and what it does. And how can I add LIE options like tattoos etc to the skin?
    edited October 2024
    Martina
    One has to update Default Resources package to Default Resources for DAZ Studio 4.23+ in DIM...
    Post edited by crosswind on
    On the first page of this thread, there's a PDF file attached by Mada, in which there're detailed explanation on LUT and MatCap setup.
    1161 x 768 - 327K
  • Ghosty12Ghosty12 Posts: 2,093
    edited October 2024
    Not sure if this has been asked has anyone worked out how to deal with flat panel grass with opacity textures, such as used in Harwoord House and FG's Haunted House? When I use Filatoon on such grass it just comes out as solid panels, and so far can't work out how to get around the problem.
    Post edited by Ghosty12 on
  • barbultbarbult Posts: 27,431
    Reload the opacity map.
    edited October 2024
    I do that well I sort of do by adding back in the cutout opacity texture used but I still get this problem.
    1874 x 599 - 122K
  • SkyewolfSkyewolf Posts: 486
     This is fantastic! :)
    edited October 2024
    ​This isn't anything special since I've really JUST had an opportunity to do more than open it up and load a few things here and there but here's my contribution. Really looking forward to poking at this more to see what I can come up with beyond the basic. It's so cool to see how much others have done with it in such a short time!
    700 x 700 - 496K
    Post edited by Skyewolf on
    Don't use outline shell with billboard type items. If you want an outline on transmapped flat plane items, it'd have to be part of the base texture, the shell outline won't work
  • SapphireBlueSapphireBlue Posts: 1,417
    edited October 2024
    I'm enjoying working with filatoon so much! It's sweet and very versatile.heart I'm going to try more stylized stuff soon beyond the toon and anime realm and see how far I can push it. Meanwhile, it's fun to just do some cute renders. This one uses the G2 Florida hair from this week's biweekly freebies.
    Post edited by SapphireBlue on
    Oh cool! That is good information - thank you! I played around with it and was able to get rid of some of the pixelation of the shadows by upping the Sub Divide of the shadow object as well as adjusting the "shadows" settings in the Filament Draw Options node. :) Thank you for the great tip!
  • HighElfHighElf Posts: 373
    Is there a way to enlarge the iris with toon eyes? I have a few models that have larger eyes, but I can't find a way to scale the iris accordingly.
    1920 x 1080 - 1M
    edited October 2024
    In the Scene Tab select the "Genesis 9 Toon Floating Iris", then in the Shaping Tab select "Eyes" and you can slide the "Eye Iris Size Larger" slider up. You can probably turn the limits off if you need the iris bigger than 100%.
    1000 x 287 - 42K
    Post edited by 3Diva on
    That's lovely! She looks like she has stage fright - just missing a microphone. :) Cute render!
    edited October 2024
    Yes, that is it. But why didn't it show up, when I typed 'eye'  into the search filter?
    Anyways thank, you are a lifesaver for those toons in my library xD
    P.s.: The setting was hidden by default. Just in case anybody else needs those too.
    811 x 1080 - 2M
    Post edited by HighElf on
    edited October 2024
    It does, if you search on "All", also with Show Hidden Properties disabled:
    554 x 246 - 25K
    edited October 2024
    For Transmapped Hair, you'll need to manually reload the trans maps once you apply the Filatoon shader. You'll then want to lower the PBR Masked Threshold to around .12 or so (give or take for personal taste). You'll want to do the same for the "Toon Outline" on the hair (the geometry shell).
    342 x 108 - 9K
    800 x 1040 - 1M
