Taking your LowPi Crowd Generation to the next level.
Requires HedgeMaker as it uses the Hedgemaker plugin for the collision detection.
The product page says "The HedgeMaker plugin is included with this product, " That seems to contradict the statement that Hedgemaker is a required product. Do you mean "The Hedgemaker plugin is used by this product."
A, crap (It was changed, first I wanted the plugin included , but that was impossible, so it was changed to require the plugin), forget to check it that text was changed or not.
I fix that!
As a learning exercise, I had a go at converting some clothing from M4, Genesis and G2M to keep me going while I await the (promised?) medieval add-on set.
Quite a bit of work with Decimator, texture reduction, mesh-grabber etc, then setting up a Wearkit then using Set Builder. So I was determined to post it even though it's not the best image ever (probably too close to the foremost figures)
I hope to pick up the latest add-on scripts today, even though it gives me even more to learn!
When the "promised" medieval set shows up, you can combine your wear kit with it for more variety. Good work. I agree, it is a lot of work converting existing clothing, but I do it a lot and enjoy it for some reason. I guess it gives me a sense of accomplishment.
Yes, I am planning to have a crack at Regency clothing then maybe Edwardian when I have been through all my Medievals. I agree about that sense of accomplishment - even if I could probably do better on the conversions
We are already ahrd at work on the next one after that, which is going to need some new features here and there for better crowd control. We started a monster lol
Sobald ich mehr als 30 Personen (25% Instanzen) generiere, benötigt mein PC ca. 1 Minute pro Person. Bei den 30 Personen kann dies innerhalb einer Gesamtzeit von 3 Minuten erledigt werden. Es werden nur 4 Begrenzungsmarkierungen verwendet. ElDie CPU arbeitet mit minimaler Last und auch der Arbeitsspeicher ist mit nur 7 GB belegt. Ich verwende einen AMD Ryzen 5 1600 Six-Core Prozessor 3,20 GHz mit 16 GB RAM und eine GEFORCE RTX 4060 TI Grafikkarte. Wie kann ich es beschleunigen?
Is it possible to replace LowPi characters entirely
and use only scripts with some other low poly characters?
No, it only works with LowPi
Ok, thanks for the explanation.
A little teaser of what will come, when it's done, for LowPi Crowd Generator, Crowd Generator Plus.
All markers are made visible here ( you seethere are only border markers)
Today made an image with the new Neo Tokyo and added a bunch of LowPi.
Looks great, @barbult, and I like the composition of the image very much.
Thank you, Artini. I moved my LowPi crowd to the Streets of Japan 2. They don't look very Japanese. They must have just come off of a tourist bus.
Great imags @barbult! And either a tourist bus, or a cruise ship.
That's too vague for anyone to help you. You need to describe:
I accidently posted my LowPi mummy renders in the wrong thread, so I'm reposting them here where I meant to put them.
LowPi Mummies and Skeletons come out at night.
More mummies.
What LowPi stuff do you have installed?
Did you add any sets to the list?
If you just select a set but not add it, no tags are loaded, sounds like that.
The arrow points to the add button...
Then it will load the set
LowPi Crowd Generator Plus Extension is released!
https://www.daz3d.com/lowpi-crowd-generator-plus-extension
I fix that!
The storepage description has been updated!
Nice work MelanieL
Great to see LowPis in the wild
Looks very nice, @MelanieL
and I like how the converted clothes looks a like.
Thank you both!
the medeival set is coming, I promise :)
Those are very nice mummies!
The mummies were converted from this Egyptian bundle. Since then, I've also converted the old M4 bandages.
Mummies and Skeletons and Zombies, Oh my!
Halloween must be on my mind lately.
The wait is over!!
Medieval life is here!
https://www.daz3d.com/lowpoly-crowd-creator-expansion-medieval-life
