Quick "Select Children" script
ImagoImago Posts: 5,797
Someone knows a script to quickly select all the children of a selected bone?
  • felisfelis Posts: 6,583
    What do you want different from select children in the scene pane?
  • ImagoImago Posts: 5,797
    In some cases it takes a lot of time to select every single child bone, especially if they are many like in the hands.
    I just need something that will select all the childs of a selected part, as I said, like the hand. I select the "base" of the hand, run the script and all the fingers, carpals and stuff is selected.
  • ElorElor Posts: 4,207
    edited September 2024
    Right click on the bone > Select > Select Children
    Edit: I forgot to write that the right click has to be done on the selected bone in the Scene tab.
    Post edited by Elor on
  • MelanieLMelanieL Posts: 7,880
    If you must must really have a script, there is one from mCasual HERE
  • TomhipTomhip Posts: 634
    In Customise you can find "Select Children" under scene view action. You can drag that to existing toolbar or create new one. It will select all children of currently selected object. I have been using this a lot to clear hands bones etc.
    Post edited by Tomhip on
    Thanks Tomhip, I'll try that.
    @ MelaniwL I have that and used it until now, but since a few new DAZ releases it doesn't work correctly anymore. If I use that when selecting stuff on the viewport, it works OK but if I select the prop in the Scene pane it selectes the whole scene's stuff.
    @ Elor Yes, I know that... But some times is a bit impratical...
    Just tried, it does the very same as MCasual's script. Selects correctly when in viewport, selects all when in the Scene pane.
    *edit*
    Solved somewhat differently using your suggestion. Thanks!
    Post edited by Imago on
    Ah, I didn't know that - I'm stuck on DS 4.21.0.5 because of my hardware and it works there still (I'm fairly sure)
