• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Sagan: A DAZ Studio to Blender Alembic Exporter
«1…17181920212223…25»
  • UncannyValetUncannyValet Posts: 267
    September 2024
    Edit: Apologies, I am stupid, and did not read the first post (well I did but i skipped over the crucial part and simply watched the tutorial)
  • TheMysteryIsThePointTheMysteryIsThePoint Posts: 3,278
    September 2024
    @UncannyValet
    You're not stupid, I should really figure out why that extra step is needed.
  • Orion_UkOrion_Uk Posts: 231
    October 2024 edited October 2024
    If anyones still about, I could really do with an Alembic (abc) importer for Carrara 8.5 pro? (single file and animation export)...pretty pretty please?
    Post edited by Orion_Uk on October 2024
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,457
    October 2024
    use the obj sequence export option in Sagan and Digital Carvers Guild obj series import in Carrara
    you can even add dynamic hair to it in Carrara
    TheMysteryIsThePoint said:
    @UncannyValet
    Not sure if it would interest you to know how this plugin is being used, but I uploaded some test animations I made recently, which used this plugin in the workflow to export HD animations to MD and Blender: https://www.youtube.com/channel/UCySoFBVqIuDAmLxS-J_83fA
    Post edited by UncannyValet on October 2024
    October 2024
    @UncannyValet
    @UncannyValet
    Wow. Of course, I'm always interested... even more so when the animation is like this :)
  • huntergeenhuntergeen Posts: 43
    November 2024
    I tried copying the material from Diffeo to the Sagen Alembic model. Most materials work, but for the male genital area, it doesn’t work at all. I tried with Dicktator, Male Genitals, and HD Penis for Genesis 9, but it didn’t work. What should I do? I also tried copying the UV, but that didn’t help.
    November 2024
    @huntergreen
    I'm sorry, I don't have any of those assets, so I can't debug the problem very well.
    And "it didn't work" doesn't help much, either.
    But something that I can guess at is: did you select the option in Diffeo to alphabetize the material slot names? Are they all in the same order?
    Are all the normal maps for the materials found, or is it red because the name is different and matches the Diffeo object, but not the Alembic object?
    November 2024
    I used the method of copying materials from Diffeo, assuming each material would match with the Alembic one by one. However, the results were incorrect; for example, some materials turned completely black or appeared in the wrong areas. This issue occurred with Dick
    November 2024
    Or you could recommend a compatible male gen asset to me, or even a fem gen one as well. Then my issue might be resolved immediately, as long as the clothing doesn’t cause any errors.
    November 2024
    I asked you to check several very specific things. Did you do any of those?
    I cannot recommend a compatible asset because all assets with fixed topology are supposed to be compatible.
    So, I can try to help you, but can we please check the most obvious things that I suggested, first?
  • PadonePadone Posts: 4,063
    November 2024
    Be sure to import in diffeomorphic without merging geografts, also without merging materials of course, as Sagan relies on the original daz materials to be preserved. If you merged geografts or materials in easy import may be this is what confuses Sagan.
    @Donald, anyway it would be better if you copy materials by name rather than by slots, so Sagan would be more robust when merging happens.
    November 2024
    Alphabetize the material slot names is selected. It matches somewhat, but the count isn’t the same. For example, Diffeo G9 has 7 materials, while Alem G9 has 12. In Diffeo, at the easy import Daz step, I deselected everything.
    November 2024
    the image
    2560 x 1600 - 2M
    November 2024
    There may be shells with extra materials in the daz scene, in that case diffeomorphic adds the shell as an extra material layer so Sagan should just ignore the shells when exporting. Not sure if there's an option for that.
    November 2024
    Thanks for your insights, @Padone
    Sagan used to copy materials by name, and I can't remember the exact reason, but I think it was because I couldn't reliably calculate the same material name that Diffeo used. I think this problem might resolve itself when I get around to putting in the code that David Vodhanel figured out to resolve the hidden faces associated with geografts.
    November 2024
    An update on the Geografts.
    David's code works perfectly, but identifying the hidden faces does cause another problem: If we don't encode the hidden faces, the vertices that make up those faces are still encoded, and we end up with loose vertices in the figure where the geograft connects to the figure. Removing those unused vertices is easy enough, adjusting all the other data is easy enough, but this is going to exacerbate the problem of vertex mismatches between FBX, Diffeo, and Sagan. Even if the vertex count is equal, the vertex order is likely to be different.
    I'll finish the implementation and then we'll see where things stand.
    November 2024
    "I can run it via DAZ Script IDE?
    November 2024
    @huntergeen
    It's a plugin, not a script. You'll have to wait for me to update and release it.
    November 2024 edited November 2024
    If you can make it possible to read .abc files in Python, that would be fantastic! That would make my Diffeo sequence in the export process work much faster. Right now, I'm using .obj instead of directly writing vertices, which is already 2.33 times faster. If I combine it with yours, it will be 20 times faster than the original method.
    Post edited by huntergeen on November 2024
    November 2024
    If I'm not mistaken, there's already a Python API to read Alembic files, as part of the official Alembic releases.
  • larry.springlarry.spring Posts: 8
    November 2024
    Hey!
    Plugin seems to be great, but I have no option Under Edit to actually use it :(!
    DAZ says it's installed, but as I said, no Option under Edit...
    Thanks for any help!
    November 2024
    Im STUPID! Found the solution... maybe reading helps out xD!
    larry.spring said:
    Hey!
  • dazzyddazzyd Posts: 10
    December 2024
    Hi! Does the plguin work with the latest daz update? Should i update or not? Thanks
    December 2024
    Works for me. I don't expect it to break until DS5.
  • kkangstar56kkangstar56 Posts: 0
    December 2024
    alembic export doesn't work on all versions of sagan plugins How do I fix this? :(
    935 x 1067 - 248K
    January 2025
    Sorry, forum notifications appear not to be working.
    To answer your question, how should I know? You haven't shared any information that would allow me to try to help you. My only guess is that you don't have write permissions on the output directory you chose.
    January 2025
    Version 3.6.0.0 is up. It may fix the UV issue with geografts and geoshells. I tried it on the few geograft assets that I have, and it seems to work. Let me know.
  • mindsongmindsong Posts: 1,747
    January 2025
    Thanks for poking at it as you do - it's quite a useful tool!
    cheers,
    --ms
    January 2025
    cheers,
    --ms
    Thanks, ms... your words always motivate me.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
