Gallery header size
cosmo71cosmo71 Posts: 3,609
Can someone tell me the size of the header image for the gallery?
  • HorusRaHorusRa Posts: 1,666
    edited March 2019
    Post edited by HorusRa on
  • From what I can see it takes a variety of sizes, you not really locked down to it must be X by Y size.
    The best way is probably to make a a tester image and just test and see how you feel and adjust it from there.
    Gallery header images get cropped to  960 x 400      My original one was entered at  1440 x 600      if that helps
  • MN-150374MN-150374 Posts: 923
    edited August 2015
    Everything worked fine until they changed the shop software last year. Since than the header images just look out of place, no matter what intention you had or you will have.
    And there is also the #-issue in the browser adress bar with Firefox. You click on an image to see full size and the description, but the circle is spining and spining and spining ... right round, right round, like a record. :-)
    When this song comes to my mind, I finally realize to remove the # in the adress. :-)
    Edit: Back than I switched to Firefox because there was an issue with the Internet Explorer emptying the Shoping Card at check out. Still don´t know if this had been fixed?
    Post edited by MN-150374 on
  • cosmo71cosmo71 Posts: 3,609
    Question. How have added the links underneath your post?
    click on your name to got to your profile      then click on the gear icon to get to the drop down list         click on "Edit Profile"      within that list click on "Signature settings"   you then have a panel similar to the "leave a comment" panel to design your signature
    now there is the link but you have "My DAZ 3d Gallery" and behind that you have link, how do I manage that?
    now there is the link but you have "My DAZ 3d Gallery" and behind that you have the link, how do I manage that?
    the link does not work
    can someone explain how I can create a link to my gallery please?
    now the link works but I want to have just a text that by clicking on it links to my gallery, not the url itself
    edited August 2015
    You have to select the text you want as a link, than click on the symbol marked in the screenshot.
    In the PopUp paste the adress in the URL field.
    Click on OK.
    382 x 345 - 91K
    383 x 357 - 46K
    edited August 2015
    To make it a hyper link you need to type in the name   select it, and then go to the link button that MN has shown you and insert the link to your gallery    like this    My Gallery at DAZ
    If you want it to be a different colour, you can also do that by using the colour command up there ^ the first letter A. before the question mark.
    Post edited by Chohole on
