Genesis 3 and 8 to 9 Pose Converter (Commercial)
1678911
  • Splatterbaby said:
    Hi there. I got this pose converter from genesis3,8 to 9 and it used to work well. I added it to my toolbar and when I try load it up nothing happens. I tried deleting Daz and the plugin etc but it still does not work. Any advice here would help. Thanks
    You should have your G9 character and the pose selected when you select the script. The screenshot appears that you not have a pose selected in your content library, but I could be wrong.
  • I just purchased the product for doing batch poses.  When I  double-click it from the Scripts menu, I get the error, "Can't find the required base product: Genesis 3 & 8 to 9 Pose Converter. Please make sure it is installed before running the script."  I was able to run the Settings dialog box where I assigned a shortcut, but the shortcut gives the same error.
    It was indeed installed and "Genesis 3 & 8 To 9 Batch Pose Converter.dse" appears in my "C:\Daz 3D\Applications\Data\DAZ 3D\My DAZ 3D Library\Scripts\Genesis 3 & 8 to 9 Batch Pose Converter" folder.  What do I need to set to ensure the program is found when I double-click on it?
  • Here is the log file for my error mentioned above:
    2024-10-04 16:44:39.475 [INFO] :: Loading script: C:/Daz 3D/Applications/Data/DAZ 3D/My DAZ 3D Library/Scripts/Genesis 3 & 8 to 9 Batch Pose Converter/Genesis 3 & 8 To 9 Batch Pose Converter.dse
    2024-10-04 16:44:39.488 [DEBUG] ::
    085cc16a-76b3-4c5a-828c-52aeada5a077
    G3 and G8 to G9 Batch Pose Converter 1.0 (Dev 8)
    OS: Windows 11, Build 22631, Workstation
    Bit Architecture: 64
    DS Version: 4.22.0.19
    DS Edition: Pro
    DS Release Cycle: General Release
    RKEY: 085cc16a-76b3-4c5a-828c-52aeada5a077
    Script: C:/Daz 3D/Applications/Data/DAZ 3D/My DAZ 3D Library/Scripts/Genesis 3 & 8 to 9 Batch Pose Converter/Genesis 3 & 8 To 9 Batch Pose Converter.dse
    2024-10-04 16:44:39.491 [DEBUG] :: #KWd6HB: Unable to find abs path for base product.
    2024-10-04 16:44:41.459 [DEBUG] :: #dY1w9Y: Original Pose Converter base product not found.
    2024-10-04 16:44:41.460 [INFO] :: Script executed successfully: C:/Daz 3D/Applications/Data/DAZ 3D/My DAZ 3D Library/Scripts/Genesis 3 & 8 to 9 Batch Pose Converter/Genesis 3 & 8 To 9 Batch Pose Converter.dse
  • Well if you guys aren't going to help me make your product work, I guess I will have to ask for my money back.
  • Zev0Zev0 Posts: 7,122
    edited October 2024
    Hi. Sorry I don't always get notified of forum activity. Do you have the base product installed? It is a requirement. Your log says it cannot locate the base product.
    Post edited by Zev0 on
    I don't know how to determine if the base product is installed.  All I know is that I downloaded a file, IM00088686-01_Genesis3and8to9BatchPoseConverter.zip, from Daz and installed the items in the Content folder as I normally would.  I reinstalled it again this morning, but now the Settings script won't even display the dialog box.  When I tried it, I get this log file:
    2024-10-17 10:32:30.801 [INFO] :: Loading script: C:/Daz 3D/Applications/Data/DAZ 3D/My DAZ 3D Library/Scripts/Genesis 3 & 8 to 9 Batch Pose Converter/Genesis 3 & 8 To 9 Batch Pose Converter Launch Settings.dse
    2024-10-17 10:32:30.803 [DEBUG] :: ======================================================
    2024-10-17 10:32:30.803 [DEBUG] :: Pose Converter Launch Settings
    2024-10-17 10:32:30.804 [DEBUG] :: #gK19ed: Custom Action Name:  G3 and G8 to G9 Batch Pose Converter
    2024-10-17 10:32:30.805 [DEBUG] :: #jwY7S1: Custom Action Index:  15
    2024-10-17 10:32:30.805 [DEBUG] :: #KOsoGa: Custom Action Shortcut: Ctrl+P
    2024-10-17 10:32:30.805 [DEBUG] :: #gK19ed: Custom Action Name:  G3 and G8 to G9 Batch Pose Converter
    2024-10-17 10:32:34.644 [INFO] :: Script executed successfully: C:/Daz 3D/Applications/Data/DAZ 3D/My DAZ 3D Library/Scripts/Genesis 3 & 8 to 9 Batch Pose Converter/Genesis 3 & 8 To 9 Batch Pose Converter Launch Settings.dse
    So it looks like the Settings script is executing, but it doesn't do anything.  If I run the app, I get this log file:
    DS Version: 4.23.0.1
    DS Edition: Pro
    2024-10-17 10:35:38.831 [DEBUG] :: #KWd6HB: Unable to find abs path for base product.
    2024-10-17 10:35:45.577 [DEBUG] :: #dY1w9Y: Original Pose Converter base product not found.
    I don't understand where it is trying to look for the product.
  • Note that I upgraded Daz Studio to Ver 4.23.01 yesterday.
    DS Edition: Pro
    Base product needs to be purchased and installed. The batch converter is an addon for the base product, and requires the base product.
    Oh goodness!  I didn't notice that there was a requirement for this product!  Of course, now I see what you mean by "base product"!  I will purchase it now.  Thanks for your patience with my absentmindedness.
    NP. Thanks for the support.yes
  • Hi all- I'm having the same issue here... batch converter works fine, single pose converter does not. Windows 11, DS 4.23.  I don't use the connect / smart content in DS since I keep getting the "...valid PostgreSQL cms connection could not be established..." message on startup, so I can't even if I wanted to (no biggie there, my content library still works fine otherwise). These scripts are both installed on the same external drive via DIM (since I use several different HD's for content)-  Have uninstalled, reinstalled, cleared caches, etc. nothing seems to work thus far...?
    I checked the log file, and it appears that it's trying to locate/call the script on a different drive from where it's currently installed. I did originally have all my Genesis products on that drive, but had to move some to a new drive due to space. (and there have been DIM/user snafus in the midst of the changes). These scripts are in the batch that got moved. I'm going to try to manually remove the files (from the old location) listed in the "installed files" list in DIM, then unistall and reinstall to the new location again and see if that works...
    OK, that didn't work either. I've attached the screenshot of the log file where the warning shows up (about half way down). I ran the batch converter after, and it still works fine and calls the correct location (D:GenesisChars)
    Any help is appreciated! smiley  Thanks! ~Amy / featherwitch
    2548 x 1561 - 261K
  • Hello, the script no longer works for me. I have tried to install a new one for daz3d studo 4.23 several times. It does not work and I do not get any error messages.
    I urgently need this script for my promo. -.-,
    I hope that there might be an update in the future...
    Chasoqueen
  • I have tried adding instructions.png to the suggested folder but I am still getting the error message about base pose converter not being found. The single pose converter works fine, I was just hoping to use the batch. Running Daz Studio 4.23.0.1
  • faisanfaisan Posts: 600
    Why didn't it come with the pose corrector? It was very useful and fast for me with the previous Genesis figures pose converter.
  • sir_sephysir_sephy Posts: 49
    edited February 7
    why doesn't it work???? the green gear supposed to be appear but it didn't... I used it and nothing happened.
    292 x 71 - 3K
    Post edited by sir_sephy on
    I selected G9 and selected G8 pose and look at what happened. what do I do???
    569 x 191 - 22K
    Hi. It was not needed. Having a pose selected and doing a direct conversion was a better solution.
    Is the pose file highlighted when script is ran?
    edited February 6
    sir_sephy said:
    why doesn't it work???? the green gear supposed to be appear but it didn't... I used it and nothing happened. Let me guess... it is outdated, isn't it? Nice way to take my money
    Hi. Works fine on my side.
  • Lee MoonLee Moon Posts: 926
    I just happened to use the script today to try some G3 and G8 poses on one of my G9 characters.
    It worked beautifully (as it always has.)
    I'm on DS 4.23.1.27 (Beta) on a Mac.
    The steps I use are:
    1) select figure in viewport
    2) select pose file in Smart Content
    3) select script from the Scripts menu
    4) wait a moment and the pose is applied
    5) close the script dialogue box
    This script works like magic.  I've always been very impressed by this quality product.
    Thanks, Zev0!
    Lee
    Thanks for the kind wordsyes
    I believe it doesn't work because I have a download icon on the product. It happened as I deleted all of Daz Studio and products and reinstall everything on another drive. I don't know how daz connect work but I'll find a way to solve. I will let you know once I sort it out.
    148 x 170 - 34K
    edited February 7
    I did what you do and nothing happens. your script has a icon and mine doesn't. Why?
    292 x 71 - 3K
    edited February 7
    [Oh, goodness]! this product is in daz connect-- that's why it doesn't work! How can I disable daz connect and use it through DIM???
  • Richard HaseltineRichard Haseltine Posts: 108,192
    According to your screenshot it is not installed through Connect - the arrow in a circle means it is available for installation through Connect.
    edited February 7
    I installed it and now I got this
    616 x 362 - 70K
    You should not have installed it through Connect - unfortunately the store doesn't "know" that some script products are not written in a way that works with Daz Connect instalaltion and shows them as available; stick to DIM (or manual) installation for script products unless the writer explicitily  states that they are Connect compatible..
    I managed to fix it in hard way. Now I can make my character pose easily with your product in different way. Scripts may be not work but it does work under smart content. I know it is strange but I like this way instead. good day.
  • Hi, does not work for me. I select a G9 caracter, then  a G8 or G3 pose and use the shortcut i create, and nothing happen.
    It telles me that the product isn't installed.
    1876 x 1228 - 531K
  • Hi, nothing has worked for me for a long time, since 4.23 Daz3DStudio. I have to say I find it quite frustrating.
    I have tried several things, I can't get them to work.
    1526 x 984 - 155K
    1426 x 813 - 113K
