[Released] Bone Minion for DAZ Horse 2 Poses [Commercial]
2»
  • RiverSoft ArtRiverSoft Art Posts: 6,959
    barbult said:
    This product (Bone Minion for DAZ Horse 2 Poses)  is confusing me. When I look at the user manual included in the product, it is copyright 2022 and it doesn't mention anything about horses. When I run the script to install custom actions, it only show options for people, not horses (I also own the bone minion bundle for G9).
    After installing the product with DIM, it seemed to change the compatibility base of Daz Horse 2 to the minion. That means when Daz Horse 2 is loaded, none of its compatible items show up in Smart Content anymore. I think this is a Daz QA metadata error. I think it should have been the other way around. The Minion compatibility base should be Daz Horse 2, right?
    The same manual is used for all Bone Minion products.
    Doh! You are correct about the install script.  It only installs the figure bone minions.  I should have pulled that script and included a horse specific one.
    Yes, the Minion Compatibility should be the Daz Horse 2, not the other way around.
  • MelanieLMelanieL Posts: 7,863
    edited August 2024
    I've got a problem which noone else seems to be getting.
    I installed the Horse Bone Minion using DIM. I loaded a Lorez horse and added the Horse 2 bone minion. I get error messages about missing files. (The same thing happens with a Horse 3 also, but these screenshots were with Lorez horse).
    Attachment 1 shows a missing file error for a constants file. I went to where DIM said this file should be and it has a different name. I copied to the name the error message is showing and got past that step.
    Attachment 2 shows the next error message (after I copied the first file). Again the file installed through DIM has a different name. Copying the .dse file to the name the message shows gets me through that error and the whole thing works fine.
    Attachment 3 shows the files that were actually installed. How have I got the wrong file names when people in earlier posts are apparently using it without problems?
    ETA: By the way the ReadMe file list (part attached) shows the names that I have, so why is something looking for a longer file name?
    593 x 402 - 39K
    574 x 395 - 39K
    1181 x 318 - 73K
    847 x 807 - 208K
    Post edited by MelanieL on
  • carrie58carrie58 Posts: 4,170
    edited August 2024
    RiverSoft Art said:
    carrie58 said:
    @RiverSoftArt when I try the Bone Minion DAZ Horse 2 Heavyweight I get an error message stating it can't find the Horse 2 Duf. and doesn't load ....... but the Bone Minion DAZ Horse 2 does work ..... I have set up my library different then basic cause I don't use smart content  ......could that be the problem?
    In the /data/RiverSoft Art/Common/Pose Converters/DAZHorse2MetaData.dsa file, there are 2 lines:
    FIGURE_PRESET_NAMES.pushIfNotExists('DAZ Horse 2');
    FIGURE_PRESETS['DAZ Horse 2'] = 'Animals/DAZ Horse 2/DAZ Horse 2.duf';
    These lines tell the script where to find the Daz Horse 2.duf (using a relative path).  Where is your horse located?
    Animals/Land /Domestic/Horses/DAZ Horse 2 /DAZ Horse 2 .duf.........
    But why can the basic bone minion find the .duf but the heavy weight one can't what is the difference between the 2?
    Post edited by carrie58 on
  • barbultbarbult Posts: 27,434
    edited August 2024
    My DAZ Horse 2 is installed in the default location, as shown by RiverSoft Art, but heavyweight bone minion does not work for me either.
    I was making a mistake when trying to create the heavyweight bone minion. I had never tried heavyweight bone minion before on my people figures, so I didn't know what to expect.I was supposed to SELECT DAZ Horse 2 in the pop up message. In spite of reading the manual and reading the message in the pop up, I didn't understand it. I thought it was an error message telling me something was wrong. blush After selecting DAZ Horse 2, it created a heavyweight bone minion. Now I will try that pose that I had problems with. ... And it works!
    1489 x 984 - 126K
    Post edited by barbult on
    edited August 2024
    Okay but I already did that with the Heavyweight bone minion and still got the error message ........ and I've tried both the bone minion in the scripts folder and the one in the DAZ Horse 2 anatomy folder . The one in the Anatomy folder doessn't bring up the pop up window ,the one in the scripts folder does but even with DH2 selected it throws up the error message about being unable to find the DH2 .duf
    @MelanieL I read your message several times and studied your attachments, but I can't figure out what you are referring to about longer names. I installed with DIM and the files you showed look like the files DIM installed for me. I don't get those errors. You talk about the LoREZ Horse, but the bone minion is for LoREZ Horse 2. Since you say the error also happens on DAZ Horse 3, I assume that was not the problem.
    Yes I did mean Lorez Horse 2.
    The problem is that Bone Minion seems to be looking for files named "RSDAZHorse2..." but the files installed are named "RSDH2...." (i.e. an abbreviated form of the name)
    edited August 2024
    Do you have the bone minion selected when you apply the pose that gives you the error, or are you applying the pose to something else? What pose are you using?
    (The selection rectangle in your images looks smaller than the bone minion.)
    edited August 2024
    I'll have to go back and check (on my desktop PC)  exactly at what point the error message appears - I can't remember whether it was loading the minion (which would explain the size of the rectangle) or applying a pose. Certainly when I created files of the names in the error messages (by copy then rename) everything worked perfectly.
    It's well after midnight here so I'll have to do that tomorrow. (ETA: Sorry I didn't see your reply earlier, but I was doing something else entirely tomight)
    edited August 2024
    It looks like it is not finding the DazHorse2Metadata.dsa file (the metadata files are what tells the script the abbreviations, e.g., DH2).  Is E:\Daz Data\Daz Studio Master Content\Base Animals one of the directories listed in the Daz Studio Formats section of the Content Directory Manager?
    Post edited by RiverSoft Art on
    The "basic" bone minion is the one I provide; there is nothing to find.  The Heavy Weight Bone Minion is BUILT on the fly by the script using the DAZ Horse 2.duf.
    edited August 2024
    Yea!  I was just going to ask you to do that as you hadn't attached any error or log message smiley  To me, it was the expected dialog and to you it was an error.  surprise  I am sorry I was not clear enough in the manual about how the Heavyweight Bone Minion works.
    Is it possible that some people's problems are caused by the metadata compatibility base error? I corrected that right away, so maybe that is why it is working OK for me.
    I would not think so.  That just affects what shows up in Smart Content.
    Yes, that directory is listed in CDM under Daz Formats. I will take a look at that DazHorse2Metadata.dsa file and check that it contains something sensible-looking re abbreviations.
    The only other thing I can think of is that I have other Bone Minion sets installed in a different directory (I keep my People and my Animals in separate ones) - could this be having any effect?
    I plan to switch my desktop PC a little later today, so I'll try removing the "People" directory temporarily and see what happens.
    edited August 2024
    OK, so I'm apparently the oddity for having multiple content directories! Apparently multiple Minions in different libraries just don't play friendly with each other.
    I moved "Base Animals" to the top of the CDM hierarchy and it worked fine. So I reinstalled the Bone Minion for Horse 2 Poses into the "People" directory where my other Bone Minions reside and moved my CDM setup back to how I want it.
    All is now well - here's a quick screenshot of a Gen9 on the Lorez Horse 2 using a pose for Genesis (M5) on Daz Horse 2.
    Thanks to both Riversoft Art and barbult for taking the time to look. I'm so happy to have my Minions working: I love them, they are such helpful products.
    644 x 661 - 55K
    807 x 735 - 129K
    That makes sense.  The find just looks for the first directory that matches.  Your other bone minions have a Pose Converters directory but it was empty of the horse stuff.  You could have just moved those files over to your first one in your directory list.
    But I am glad you got it working. smiley
  • MouserMouser Posts: 775
    edited May 15
    Tried your excelent horse bone minion on G8/Centaur, the horse works as advertised.
    Now if we can get the top to follow as well, I would happily pay $ for a centaur bone minion solution;)
    Post edited by Mouser on
    Have you tried something like what I did for the horse and rider solution?
