LIVE! In the store NOW!! LowPi - the Low Poly Figure, and Crowd Creator Scripts
17810121322
  • ArtiniArtini Posts: 10,541
    Is it possible to replace LowPi characters entirely
    and use only scripts with some other low poly characters?
  • TotteTotte Posts: 14,890
    No, it only works with LowPi
    Ok, thanks for the explanation.
    edited August 2024
    A little teaser of what will come, when it's done, for LowPi Crowd Generator, Crowd Generator Plus.
    All markers are made visible here ( you seethere are only border markers)
    1600 x 900 - 2M
    Post edited by Totte on
  • barbultbarbult Posts: 26,506
    edited August 2024
    Today made an image with the new Neo Tokyo and added a bunch of LowPi.
    2000 x 1500 - 2M
    Post edited by barbult on
    Looks great, @barbult, and I like the composition of the image very much.
    edited August 2024
    Thank you, Artini. I moved my LowPi crowd to the Streets of Japan 2. They don't look very Japanese. They must have just come off of a tourist bus.
    2000 x 1500 - 2M
    Great imags @barbult! And either a tourist bus, or a cruise ship.
    smileyCould be Yokohama. That's where we got off a cruise and headed to Tokyo.
  • I can't get it to work at all
    That's too vague for anyone to help you. You need to describe:
    • what product(s) you installed,
    • how you installed them (DIM is the best way; don't install inside Daz Studio),
    • what steps you took to run them
    • specifically what happened after each step.
    • Did you read the manuals?
    • There is also a video tutorial available for purchase in the Daz store if you are totally clueless about how to use it, that might help.
    I accidently posted my LowPi mummy renders in the wrong thread, so I'm reposting them here where I meant to put them.
    LowPi Mummies and Skeletons come out at night.
    More mummies.
  • I can't get it to work at all, keeps saying "you don't have any sets that match the active tab"
    What LowPi stuff do you have installed?
    edited September 2024
    Did you add any sets to the list?
    If you just select a set but not add it,  no tags are loaded, sounds like that.
    The arrow points to the add button...
    Then it will load the set
    1230 x 728 - 207K
    1274 x 772 - 241K
    LowPi Crowd Generator Plus Extension is released!
    https://www.daz3d.com/lowpi-crowd-generator-plus-extension
    Taking your LowPi Crowd Generation to the next level.
    Requires HedgeMaker as it uses the Hedgemaker plugin for the collision detection.
    edited October 2024
    The product page says "The HedgeMaker plugin is included with this product, " That seems to contradict the statement that Hedgemaker is a required product. Do you mean "The Hedgemaker plugin is used by this product."
    A, crap (It was changed, first I wanted the plugin  included , but that was impossible, so it was changed to require the plugin), forget to check it that text was changed or not.
    I fix that!
    The storepage description has been updated!
  • MelanieLMelanieL Posts: 7,807
    edited October 2024
    As a learning exercise, I had a go at converting some clothing from M4, Genesis and G2M to keep me going while I await the (promised?) medieval add-on set.
    Quite a bit of work with Decimator, texture reduction, mesh-grabber etc, then setting up a Wearkit then using Set Builder. So I was determined to post it even though it's not the best image ever (probably too close to the foremost figures)
    I hope to pick up the latest add-on scripts today, even though it gives me even more to learn!
    1024 x 768 - 705K
    Post edited by MelanieL on
    Nice work MelanieL
    Great to see LowPis in the wild
    edited October 2024
    Looks very nice, @MelanieL
    and I like how the converted clothes looks a like.
    Post edited by Artini on
    Thank you both!
    When the "promised" medieval set shows up, you can combine your wear kit with it for more variety. Good work. I agree, it is a lot of work converting existing clothing, but I do it a lot and enjoy it for some reason. I guess it gives me a sense of accomplishment.
    Yes, I am planning to have a crack at Regency clothing then maybe Edwardian when I have been through all my Medievals. I agree about that sense of accomplishment - even if I could probably do better on the conversions blush
  • the medeival set is coming, I promise   :)
    We are already ahrd at work on the next one after that, which is going to need some new features here and there for better crowd control.  We started a monster lol
    Those are very nice mummies!
    1000 x 1300 - 384K
    The mummies were converted from this Egyptian bundle. Since then, I've also converted the old M4 bandages.
    edited October 2024
    Mummies and Skeletons and Zombies, Oh my!
    Halloween must be on my mind lately.
    2000 x 1500 - 2M
    The wait is over!!
    Medieval life is here!
    https://www.daz3d.com/lowpoly-crowd-creator-expansion-medieval-life
  • gamegame Posts: 3
    Sobald ich mehr als 30 Personen (25% Instanzen) generiere, benötigt mein PC ca. 1 Minute pro Person. Bei den 30 Personen kann dies innerhalb einer Gesamtzeit von 3 Minuten erledigt werden. Es werden nur 4 Begrenzungsmarkierungen verwendet. ElDie CPU arbeitet mit minimaler Last und auch der Arbeitsspeicher ist mit nur 7 GB belegt. Ich verwende einen AMD Ryzen 5 1600 Six-Core Prozessor 3,20 GHz mit 16 GB RAM und eine GEFORCE RTX 4060 TI Grafikkarte. Wie kann ich es beschleunigen?
