LIVE! In the store NOW!! LowPi - the Low Poly Figure, and Crowd Creator Scripts
1679111222
  • TotteTotte Posts: 14,832
    The video tutorial on working with the LowPi Ecosystem is now released:
    https://www.daz3d.com/the-ultimate-guide-to-building-low-poly-figure-scenes
  • ArtiniArtini Posts: 10,426
    Great. Looking forward to purchase the tutorial, when funds will allow.
  • Lyrra MadrilLyrra Madril Posts: 282
    Lowpi Update in DIM now.  This patch address the bends on the wrists, the thigh bend CBS matches better, and a new Hair template has been added for use in rigging and conversions.
    LM
  • barbultbarbult Posts: 26,424
    Thanks. I'm traveling, so I won't be able to try it right away.
  • cheardcheard Posts: 115
    edited July 2024
    A couple of questions about using LowPi effectively:
    1. Suppose I want my LowPi adult men to have facial hair. In order to make sure the head hair and the facial hair are the same color, do I load both on the LowPi and save both out as one combined asset? Or can beard and hair be separate items with some kind of "require" flag set to ensure the same color?
    Edit: Selecting both and saving out doesn't work. Only one item gets saved.
    2. Suppose there is some wardrobe I really want to use in a LowPi crowd, but it's dForce. So far I have found this to cause problems (explosions). Tips?
    Post edited by cheard on
    to save mutiple items as 'one item' , as far as DS cares,  use a wearable preset. (select figure, then save wearable and choose the items from the list.)
     Do NOT use props on the head and shoulders, They must be rigged due to a current bug in using props on instanced figures.
    I think that whatever method Totte used for adding and coloring the side curls and bangs should work for facial hair? Something to have a look at
    Frankly I never tested Lowpi with dforce clothing. I'm not entirely sure what happens if you try to instance dforce clothing.  At any rate, dforce clothing is very sensitive and I'm betting it didnt like the conversion to a new shape.  Does it absolutely need to be dforced?
    LM
  • I made this test crowd, then ran it through Krea.  I was blown away.
    1469 x 827 - 418K
    2040 x 1152 - 2M
    Very cool indeed!
    edited July 2024
    Wow, that is amazing! I had never heard of Krea, so I went and checked it out. I tried a few LowPi images on the free plan. It worked best for me when the LowPi faces were large in the scene. When I had tiny heads, like the horse riders, the resuting faces are pretty distorted,
    Two_20LowPi_20on_20Horses_20again_20front_20with_20G3M_20skin_Camera_201-enhanced.png
    2048 x 1536 - 4M
    1568 x 2048 - 977K
    1568 x 2048 - 2M
    2000 x 1500 - 2M
    1000 x 1300 - 52K
    2000 x 2600 - 1M
    Post edited by barbult on
  • DoctorJellybeanDoctorJellybean Posts: 9,750
    edited July 2024
    The close-ups are pretty good! What did you use in Krea, Enhance?
    Post edited by DoctorJellybean on
    Yes
    Yes
    Thanks, I might just give it a try.
    Yes
    It is pretty easy. I didn't even read any instructions. I just clicked on what seemed obvious. It might do better if I investigated more.
  • luci45luci45 Posts: 2,912
    I've missed a lot in the past three weeks.
    barbult, your renders are great! They make me want to get back to LowPi again. Thanks for the mini-tutorial on attaching props. It helps me a lot as I get lost (or distracted) sometimes when there are many steps.
    The Krea enhancements are cool - it didn't even mess up the hands. Will AI ever learn to do hands?
    Totte, your video tutorial looks wonderful. On my wishlist waiting for a sale.
    edited July 2024
    Speaking of Krea, this isn't LowPi, but I thought it was a hilarious result.
    I started with a simple render of Richard Haseltine.
    Somehow Krea Enhancement thought there was some kind of face on the end of his tail.
    So I did an edit of the enhancement and prompted it to not put a face on the end of the cat's tail. So, instead, it put a very detailed cat face and bow tie on the end of the tail!
    2000 x 1500 - 732K
    2048 x 1536 - 3M
    Richard_20the_20cat_20Omni_20Hair_20Shader_20Fur-enhanced told it no face on tail.png
    2048 x 1536 - 3M
    Hehe, really cool!
  • Richard HaseltineRichard Haseltine Posts: 108,882
    Eyes in the back of my back, that would be useful.
    I have never thought of you as being "two faced".
    Duplicate faces are probably attributable to a CloudFlare Gateway error.
    I had to read that twice before I got it. Maybe you should have duplicated the message. laugh
    Richard "Janus" Haseltine?
    edited August 2024
    It took me all day to make this picture. Yesterday I made the ascending and descending stair poses. Today I rendered two LowPi crowds with those poses. The, following a previous tip from Totte, I manually selected the LowPi I wanted from the crowds and placed them in position on the stairs. In some cases i changed their clothing or hair or clothing materials. For a few, I added handheld props and applied the appropriate hand/arm/upper body pose. I think there are about 36 LowPi in this scene. I sort of lost count.
    2600 x 2000 - 4M
    @barbult: That is a super well done LowPi scene!
    edited August 2024
    Thanks, Totte.
    My LowPi people were calling out for a grittier interpretation. Here's one more, with postwork and a little different camera angle.
    2600 x 2000 - 3M
  • barbult said:
    Thanks, Totte.
    I prefer this version, it's very well done.
    Well done, @barbult
    I adore your devotion to this higly complicated for me LowPi set.
    edited August 2024
    barbult said:
    Thanks, Totte.
    Thanks, I like it better, too. The name of the environment is XI New York Stairs (with a few mods I made). The black and white suited the NY vibe better, I thought. But it was only an afterthought after posting the first version.
    edited August 2024
    I own Look At Me II Pose Control and I discovered a few weeks ago that it works on the head of LowPi. It doesn't work on the eyes, because LowPi does not have "eyes" that can be posed (they are just surface textures). It also doesn't work on chest or abdomen, because LowPi does not have those bones either. I wonder if it would have worked if the Torso1 and Torso2 bones had been named more consistently with other character models. Anyway, the head posing is useful on its own. Here I had already used a direction marker to make the LowPi people face forward, but I used Look At Me II Pose Control to make them raise their head and turn it slightly more toward the camera in the center.
    In the second example, I moved the camera and reapplied the Look At Me II Pose Control to all selected LowPi people at once.
    Let's all look up!
    2000 x 1500 - 1020K
    2000 x 1500 - 492K
    2000 x 1500 - 1002K
    edited August 2024
    Question: How do I get the shoes with heels (like in the Modern Business or formal wear) to pose correctly when used with the crowd generator? If I just load a LowPi and apply the shoes, they apply and pose the feet correctly, but when a crowd is generated, the feet are all wonky and the shoes are not posed properly on the ground. It looks bad.
    1347 x 827 - 95K
    I guess that has to do with which poses are applied, not certain though, or the Fake IK going nuts due to feet rotations? ( not at my DS machine at the moment)
