new to hdri problems
Hello - I am new to hdri images - just gon through the DAZ masterclass on youtube dealing with it.  I downloaded Dresden Station Night from Poly Haven - I created an envriomental node, with infinite sphere with ground and put the image in. It looked perfectly fine in filiment, but when I rendered it in Iray this is the result.... Is there a step I am missing? Thank you in advance for any help that you can give. :)
  • GordigGordig Posts: 10,626
    edited July 2024
    The trick with HDRIs is that they're fundamentally 2-dimensional, so they only look completely correct at world zero. Adding a ground plane changes what DS thinks world zero is, causing those distortions you see. I just popped that HDRI into DS myself, and found that I had to change ground position to manual and raise ground origin Y to about 224, and then it looked normal again.
    edit: on further investigation, the HDRI looked normal, but that puts the ground plane way too high, so that's not really a workable solution. It's only the ground plane that introduces those distortions, so there might be some additional tips about using an HDRI with a ground plane so that you can compensate more easily.
    Post edited by Gordig on
  • Thank you - I will start from scratch and try a new hdri image :)
  • This one is better ! I think the problem was including the ground plain, plus the order I was doing things. This time I put the background on first, moved the 'camera' a small degree to where I wanted the man, and then added him and everything seemed to work!.
    1920 x 1920 - 5M
    It might be worth getting Catcher Plus or Iray HDRI Toolkit, because I could only get those distortions to occur when the ground plane was enabled, and either of those kits would let you get ground shadows without the actual ground.
  • THanks for the tips - I purchased the resources - now wI have to learn how to use them :) One step at a time :)
  • HylasHylas Posts: 5,245
    For scenes that show a characters feet I recommend using HDRI's only for skies and distant scenery. Ground and close scenery should be actual geometry.
  • FishtalesFishtales Posts: 6,216
    edited July 2024
     Why? I used Dresden Station HDR in this old render. I also have others using HDR's.
    1920 x 1080 - 355K
    Post edited by Fishtales on
  • jjoynerjjoyner Posts: 761
    Gordig,
    Do you have experience and/or success with using Catcher Plus to produce shadows on 2D images?  I started a thread asking for help on this yesterday.  https://www.daz3d.com/forums/discussion/694576/catcher-plus-3d-universe#latest
    Thanks.
    jjoyner said:
    Gordig,
    I don't actually own either product, don't use HDRIs in the way the OP is trying to, and no longer render in DS.
    edited July 2024
    Fishtales said:
     Why?
    Let me quote yourself back at you, from this old thread about this very subject: wink
    Fishtales said:
    I have found some work, most don't and that is with a lot of work :)
    tldr: too much hassle.
    Post edited by Hylas on
    Hylas said:
    Fishtales said:
     Why?
    Three years ago. Hopefully I have moved on a bit since then :) Fair enough though If you can't spend the time to get them to work. I am retired so have all day most days to jump in and out of Daz Studio, not everyone has that luxury :)
    edited July 2024
    Gordig said:
    jjoyner said:
    Gordig,
    225 x 225 - 5K
    Post edited by jjoyner on
    The Matte Function in DAZ Studio is what I use when needed.
    Tutorials here.
