Adding to Cart…
I had the same experience. Not to knock OOT, but Slosh's product is the better one, IMO. It works with more hair, especially some of the ancient V4 stuff I still use.
I'm happy to have the OOT product as a backup, but when converting hair for Iray, I always try UHT first. (Actually, I try the default shader first, touched with the default Uber Iray. About 1 time in 10 it looks best of all, for whatever reason.)
Yes, though some colors are better than others. I don't think it makes as much sense for the "artificial" colors, because those are from a bottle, and in the real world aren't varied much, if at all. I think the attention would have been better if these were about sheen and texture. I don't think I've ever used the bottle colors, as to me they don't look real, but they're there for you to open in Photoshop and tweak. I also took the black and crushed it a bit -- too many of my characters looked like they were going prematurely gray!
I use this shader on EVERYTHING. Used here on Liliane Hair for V4 (SWAM) and PixiePerfect Hair for Genesis 2 Female(s) (goldtassel). Both of these were simple click-and-go applications.
Seriously amongst the best products I've purchased for use in Iray.
Wow, two really strong renders :) I love them both. That Pixie hair with all the curls is great. I have to check my library and see if I have that one (I have most of goldtassel's hair)
For skullcaps, I've been first applying the UHT to the skullcap layer. I then go into each of the texture channels and select the ORIGINAL skullcap image/opacity/bump, making sure I pick the lightest texture in the original texture's folder (or a bump map if available). I can then use the color value for the skullcap Base Color map to adjust it to something that closely matches the UHT shader I've chosen. Frequently, one of the base skullcap textures works fine without having to fiddle with the texture color at all. Otherwise, just applying the regular DAZ ubershader to the skullcap and reducing the glossy weight to 0 works, too.
I still love this product! UHT on Udane Hair on Genesis 3 Female.
I finally got around to trying this and it works perfectly!!!! It is a pain to have to open each channel's image in LIE, but it works, so the effort is worth it. Thanks for the great tip!
I purchased this product and have been playing with it this morning.
Some hair products sell additional colors seperately. Others don't have extra color options at all. This product can provide these extra colors and makes it a bargain purchase for this reason alone.
Yes, it's very handy. Lends lots of versatility to hair!
