Bethany 7 - a different shape!
1235»
  • Cris PalominoCris Palomino Posts: 12,669
    edited August 2015
    ZDG, I loaded the G3F base, loaded the basic wear clothing, as I see you used it in your examples.  I then dialed up the Head 06 and Body 06 (the largest of the shapes) in my Metamorphosis set, so they are not standard G3F. As you can see, I had no trouble; I didn't even add a smooth modifier.  What is your process that you are getting poke-through?
    500 x 650 - 132K
    500 x 650 - 121K
    Post edited by Cris Palomino on
  • There seems to be adeveloping current of comments not about Bethany but about people with the same general body shape as Bethany. Please remember that this thread is going to be read by a wide range of people, and refrain from comments that can be taken out of the world of 3D characters and into the world of real people.
  • Oso3DOso3D Posts: 15,095
    Tinkering with something Bethany-like in G2F. Having a devil of a time getting the skin color right, and the face is... very approximate. AH well. ;)
    do you use skinbuilder/skinbuilder pro? can create some nice skin tones, makeup and eyebrows with that still bit of guess work guessing colours and tinting but still good
    If you do a double carriage return after the quote, it will separate you from the quote and it won't become part of it.  ~Mod
    I do have Skin Builder, and perhaps that would have been easier than all the tweaks I ended up going through to get El Rafaga skin right.
    As for Elisabet's nose, I think the issue I was running into was that Bethany's nose is basically 'tilted' downward a little. I wouldn't be surprised if it was a morph somewhere, just not one I have. I also ended up making the nose ridge too high... she looks like Bethany's older aunt, maybe. Heh.
  • RAMWolffRAMWolff Posts: 10,369
    I'm noticing that the Thumbnails are now opening in a new tab!  YAY.  The inline images are still opening the same tab.... great examples of Beth!
