UltraScenery - new(er) territory [Commercial]
1272830323372
  • davesodaveso Posts: 8,262
    edited June 2024
    I'm beginning to like the pouptput of USC2, but it's a slow one ... my current render has been sloggin for 1.5 hours and only at 25%. Its dense, with a sky add on, fog, and USXT but still
    Post edited by daveso on
    edited June 2024
    here is the render at 26%. Do you think it could be basically done already, or what is the advantage of keeping it rendering. Its basically at 2 hours right now
    546 x 594 - 356K
    1267 x 953 - 2M
    What version of Daz are you running? This is the sort of thing I'm seeing since upgrading Daz.
  • felisfelis Posts: 6,526
    For the record, I am using latest beta, and have not seen any issues so far.
  • ArtiniArtini Posts: 10,904
    edited June 2024
    AnEye4Art said:
    All the rendered US2 artworks are great. Adding the bunnies to the scene is next-level eye candy.
    Thanks a lot.
    More bunnies...
    1920 x 1200 - 2M
    Post edited by Artini on
    edited June 2024
    4.22.0.15   I am sort of holding offf on .16 but maybe it doesn;t matter anyway. I have a Nvidia 4080 so maybe it should render quicker. The final took just over 2 hours. 2:0:25 exact.  The scene contains USC2 with Skies of Economy and USXT. I forgot what biomes..I think Woodland
    If you look in the log, are you then actually using your GPU?
  • richardandtracyrichardandtracy Posts: 8,077
    That is absolutely, totally & utterly stunning..
  • MelanieLMelanieL Posts: 7,872
    Wow, I love that image! I'd call it done enough (I'm a CPU renderer though and maybe have lower standards than you?)
  • TotteTotte Posts: 15,134
    edited June 2024
    A little teaser for what's hopefully arriving for UltraScenery2 daz soon...
    Mask Builder II
    1000 x 1300 - 730K
    Post edited by Totte on
  • AnEye4ArtAnEye4Art Posts: 868
    Nice.
    I was wondering. A while back in this thread, I recall you first mentioning performance issues and at the time, I was running 4.21 release and 4.22.1.x beta - no problem rendering USC scenes in either. Since upgrading my release Daz in early May, I now have 4.22.0.16 - and I also have the same problem you were reporting then. As I've mentioned in this thread, my beta Daz runs great - can whip out complex USC scenes in minutes - but my main instance now takes ... who knows how long. I've never let one go past 45 minutes (at about 15% completion, the last time I let one go that long). Same scene, same computer, same drivers. I tested turning off all my plug-ins (in production - the beta instance doesn't acknowledge the non-Daz ones) to no avail. The only other obvious difference is 4.22.0.x vs 4.22.1.x. At this point, I'm just hoping that when the release series gets to the 4.22.1.x track the problem self-resolves. In the meantime, I'm rendering more complex USC scenes in my beta Daz.
    that's interesting for sure.
    yes -- 2024-06-08 22:53:05.940 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Device statistics:
    2024-06-08 22:53:05.940 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 4080): 427 iterations, 2.370s init, 7206.844s render
  • alexhcowleyalexhcowley Posts: 2,409
    Mask Builder II
    Totte,
    I will be lying in wait with a fully loaded, large calibre credit card.  "Daz soon" sounds a little ominous, though. Does this mean it will be out before the end of the year?
    Incidental issue: that log cabin looks really good. Where did you find it?
    Cheers,
    Alex.
    alexhcowley said:
    Mask Builder II
    Totte,
    Cheers,
    Alex.
    DAZ Soon is as close as I can estimate ;-)
    The cabin is from this set: https://www.daz3d.com/thatched-cabins
  • DoctorJellybeanDoctorJellybean Posts: 10,118
    edited June 2024
    alexhcowley said:
    Totte,
    Cheers,
    Alex.
    Totte replied lol.
    Post edited by DoctorJellybean on
    edited June 2024
    Just found what cause very long response for Daz Studio in US 2 on my computer.
    I have tried to use Ecology Preset: TA Dry Desert 04 on a 128 m terrain.
    Rendering went well, but there were so many Coconuts (forest type) 154333 instances
    so I disabled that layer, because US 2 are missing Palms.
    Then I have tried rendering again.
    When I was trying to save the render, Daz Studio becomes not responsible
    for a couple of minutes.
  • memcneil70memcneil70 Posts: 6,115
    AnEye4Art said:
    memcneil70 said:
    I also had an update to my Nvidia drive this week. The Studio Driver is v. 555.99 released on 4 Jun 2024. The Game Ready Driver was updated on the same day. My flatmate has that installed on his laptop for a GTX 1080.
    I crash on my RTX 4090 only when I forget that my 32Gb Ram/Vram cards will only tolerate just so many changes/try outs in Daz before it gets annoyed and crashes on me. I need to be more disciplined. Save and reboot.
    I have the latest studio driver v.555.85 released on May 21 2024. Daz studio v. 4.22.0.16
    Ah, that may be the difference. While I have both versions of the Public releases of Daz Studio, I primarily work on the Public Build of the Beta which is at 4.22.1.150 (I am on my laptop that has Win 10, a GTX-1080 card and is currently rendering so I can't double-check the version number.) This is my habit on all four computers I have Daz Studio installed on.
  • steelrazersteelrazer Posts: 11
    Ultra Scenery 2: Unable to load or use classic content. I have considerable classic Ultra Scenery content, but cannot access it in the new US2. Only the new content shows up, and in the Classic content area the dropdown boxes or browse does not show up any content. The preset boxes are greyed out and there does not seem to be any way to access anything. Any ideas? Thank you.
    So are you saying that I should update to the latest public build? Because I don't see any updates in DIM.
    edited June 2024
    There's a small box in between the down arrow and the words "Features" and "Ecologies". Click on that and all should appear.
    Cheers,
    Alex.
    Post edited by alexhcowley on
  • Richard HaseltineRichard Haseltine Posts: 111,467
    Do you have the Public Build (beta) in your acciunt and downloaded or installed?
    Thank you very much, alexhcowley!!! Perfect!
    edited June 2024
    Edit: I found it. Thanks.
    Post edited by AnEye4Art on
    edited June 2024
    US2 finally worked for me but only in the latest public build 4.22.1.150. The terrain is no longer deselected when creating the terrain and it works super fast. I had only one crash with the beta and that was using the layers. But the crash was not as violent like before, it was very subtle. Thanks Richard Haseltine.
    2330 x 942 - 2M
    US2 (and my pc) passed a stress test by keeping all the layers under ecology layers for the USC woodland 05 ecologies turned on while changing to different ecologies, adding layers and making other changes without a crash.
    2179 x 905 - 4M
  • paulawp (marahzen)paulawp (marahzen) Posts: 1,797
    edited June 2024
    Wabbitses!
    Finally getting a chance to test out some things I picked up in recent days.
    1000 x 1000 - 956K
    Post edited by paulawp (marahzen) on
  • barbultbarbult Posts: 27,529
    Wabbitses!
    Oh, that's so nice! You should post it in the rabbits commercial thread. Which rabbit species is that one?
    Wabbitses!
    These guys are Swedish Hares.
