PuffBall
Not sure if this is the right place to place this. I have been having an issue with puffball it is not rendering properly. Some advice please.
Rendered in Iray it looks even worse.
Is this an interior scene?
What's your lighting rig look like?
Iray and I have been fighting about interior lights for some time now-- 3Delight can operate on the headlamp, but it never seems to work the way I want it to.
Also, did you turn the headlamp off for an Iray render and then not turn it back on when you switched?
It's also possible that you have Iray mats on everything for a 3DL render. Not something 3DL appreciates, especially with things like shaded glass.
First was in 3d delight, no I ray on and no lights in scene, just the figure. I tried Iray because I thought that might make a difference but it just made it look worse.
Alright figured this out. There are two sets of mats one in pose and one in materials. If the one in materials is used it gives messed results if you relode with mats from pose directory everything works the way is should.
The one in materials I would presume is for Poser.
