can anyone make her eyebrows smaller for me?
Toobis
in The Commons
Or just generally less pronounced? I am using an obj. and its working ok except her eyebrows are too large and I can't seen to correct it. I have played around with the surfaces for ages and but with no real luck. I am not sure what to do. Can anyone take 10 mins to load up the lara obj. file from me and correct her eyebrows so they don't look so thick? I am really stuck on how to do it myself. Thanks. (warning: obj. model contains nudity) please private message me if you can help.
That looks like the diffuse map is not lining up with the rest, in a way. either the UV/UDIM mapping is not correct, or the diffuse map is way off on the size of the eyebrows. It may be very easy to fix in PS/GIMP, if you know how to use them (I'm not that good myself).
I bet the bump map for the eyebrows don't match up with the diffuse map when compared side by side.
Either that or the transmaps are not set up correctly, as also the eyelashes are having issues.
And here I thought it was a Michael Jackson morph...
Transmaps are my guess too.
