Oso Toon Shader
Has anyone gotten [Oso Toon Shader] to work properly? Where is the Emission Type setting? Searching in Surfaces and Render tabs show nothing. Instructions that came with the product attached.
https://www.daz3d.com/oso-toon-shader-for-iray
Post edited by waterswebdesign on
  • Richard HaseltineRichard Haseltine Posts: 112,036
    Pleasea attach the image, embedding doesn't work (for inline images attach the image and link to that, or have an external source to link to).
    Where are you seeing that it supports emission?
  • The instructions say "Select all objects - Apply shader - Turn off all lights - Set render max path length to 1 - Set Emission Type? to Base Color - Adjust surface's Alternate Luminance to taste". These are the only instructions it came with.
  • Oso3DOso3D Posts: 15,129
    So you selected the object, applied the shader to all surfaces, and aren't seeing Emission Type? parameter?
    The shader is a custom shader, you have to select the surface of an object so the shader preset can be applied.
    Hey Oso! I was able to fix it. I simply uninstalled and re-installed the bundle :) I was getting an "Operation Failed" in the logs when trying to apply but it wasn't showing anything on my end when I clicked on it so I didn't originally think to check logs.
