What new Iray stuff do you hope to see?
2»
  • kyoto kidkyoto kid Posts: 42,162
    edited July 2015
    ...so can you use skydomes with the Iray sun in interactive mode?
    Not been very pleased with results from many of the free HDRIs I've downloaded and don't see spending 30$ - 100$ for a single high resolution/quality HDRI sky a cost effective solution.
    Post edited by kyoto kid on
  • ToborTobor Posts: 2,300
    RAMWolff said:
    Thanks so much Tobar!
    You're welcome! And that's Tobor - robot spelled backwards. (Okay, it's a 50s thing.)
  • tl155180tl155180 Posts: 994
    edited July 2015
    I remember someone saying that you can use the 'clouds-only' skydomes from this set (https://www.daz3d.com/ultimo-paradiso) with the Iray Sun-Sky settings because its basically a skydome transparency map with some clouds on it. This way the clouds actually cast realistic shadows on the ground as well, apparently. I haven't tried it myself because I don't have this set yet, but maybe more transparency skydomes like this would be the answer for Iray clouds?
    Post edited by tl155180 on
    ...I remember the film.  Tobor the Great
    Interesting in in that he was essentially designed to be robotic explorer in effect foreshadowing what NASA has been doing for the last several decades.
    OK, back to Iray stuff...
    I'd like to see ATI support . . . (fat chance, I know!)
  • ScavengerScavenger Posts: 2,674
    I'd like an easy way to see the hdri map that it's using so you can position it better.  Changing degrees is only useful if you know how things are already.
  • Fixme12Fixme12 Posts: 589
    K T Ong said:
    What new Iray stuff would you really like DAZ to come up with?
    I basically just want two things: (1) WET SKIN for Genesis, and (2) VASCULARITY for Genesis. (Genesis, please -- not G2 or G3. I don't care whether they work with G2 and G3 as long as they work with G1.)
    Let me have these two things (I'll pay, of course), and I'm contented.
    (Well, maybe (3) an Iray version of the Grass Shaderhttp://www.daz3d.com/grass-shader-for-daz-studio ) would be nice, too.)
    Over to you.
    What about good tutorials? Prefer tutorials over new same content over and over again.
  • alexhcowleyalexhcowley Posts: 2,407
    This is exactly my issue.  Everyso often, I spend a few hours wrestling with downloaded HDRIs and all I seem to get is blurry grey skys.  Fiddling with the dome parameters doesn't seem to make any difference.  I'd love a turnkey solution to this problem, optimised for DAZ Studio - click on the preset and off you go.
    Cheers,
    Alex.
  • ToyenToyen Posts: 2,051
    A very specific layered skin shader that is created just for rendering human skin so we would not have to use the default iray shader with tweaked settings.
    I believe mental ray (another renderer by Nvidia) has a skin shader (at least the maya version) so it would be nice to see something like this for Iray as well.
    If we had some kind of dynamic hair system in DS I´d also say hair shader but right now that is unnescessary.
  • IkyotoIkyoto Posts: 1,159
    kyoto kid said:
    ...with regards to skydomes, you will have to hope for good high quality HDRI skies (like I suggested above) as skydomes block out the Iray sun.
    I was just gonna ask for more hdri setups. these are a LOT of fun. I'd love a tool to make them from rendered sets....
  • K T OngK T Ong Posts: 486
    K T Ong said:
    You should look on rendo for zev's vein maps  for M4/V4; that should work for the base genesis.
    They do...quite nicely.
    In Iray??
    You'll have to adjust the materials to work in iray. Since we are on Genesis 3, you will probably make use of maps for G2 and use the map transfer tool to convert any textures to either M4 or M5 to use on base genesis and copy any settings to get them to work. I don't see the effort happening for Genesis now for such products, much less them gettng accepted in the store. Unique characters for genesis could still be accepted, but i doubt anything else. The return is no longer there to make genesis 1 products, so you'll have to make your own workarounds.
    Guess it's good old REALITY (lux) for me, then. (Shrugs.)
    Pity. Iray could have been such a great renderer.
  • RAMWolffRAMWolff Posts: 10,373
    Oh dear.  I'm so sorry Tobor!  Or can I say Mr. Roboto?? cheeky
    In Iray??
    It is a good renderer. However, it's not a make art button; you'll have to put in the work, especially when you are working with figures that have less support or don't directly have the items you need. But DS has the tools so you can convert it to what you need, so it's not like you're not able to use items to your benefit.
    To add to male-M3dia's comment there is the iRay Uber Base.  Click on it while holding down the Ctrl key on the keyboard to keep your texture safe and it will convert the 3Delight settings to iRay.  Very simple.  You can tweak to your hearts content after that and then save the scene out so you have it safe.
  • RCTSpankyRCTSpanky Posts: 850
    Grass-Shaders like the ones from AoA and DT or the one in tis video () would really be great in Iray. To get more back to the topic tile "What new Iray stuff do you hope to see?" I would also like to see "Look At my Hair" and/or "Garibaldi Express Hair System" for Iray.
  • vwranglervwrangler Posts: 5,003
    If you have the disk space and bandwidth, you might try the HDRs from noemotionhdrs.net -- those are high resolution, and MASSIVE; 200MB at the low end and (so far) about 350MB at the high end. Also, free. They don't use backplates or a separate REF HDR, but they don't need them.
    For the skin shader, have you tried http://www.daz3d.com/beautiful-skin-genesis-2-iray-bundle or is that not what you meant?
    As far as hair shaders go, there are three separate products for hair shaders (non-dynamic) on the market now, two here (one as part of MEC4D's Unshaven) and one at Renderosity.
    Hey there wrangler, no I meant a shader that is specifically created to simulate human skin that has unique parameters.
    Here is Arnold´s skin shader for example - https://support.solidangle.com/display/AFMUG/Skin
    As you can see, it has unique parameters such as 5 different layers and can also be used to create other things than skin.
    If anyone were to come up with it, I think it would have to be Nvidia themselves or some kind of developer, don´t think PAs program these shaders.
    Over to you.
    ...in PDF format.
  • DestinysGardenDestinysGarden Posts: 2,553
    Daikatana said:
    scatha said:
    fabric shaders, grass, stone, wood, etc
    This
    Working on it frantically. Hang in there.
    There is an Iray compliant version of LAMH on the way.  Alessandro is testing it at the moment.
    Cheers,
    Alex.
    ...of course I had to go the Garibaldi route.  So that means tonnes of polys to render.
    I'd like to see Iray write convergence percentages to the log file, not just number of samples...would make checking things after the fact a lot better.
