My Daz3D keeps crashing when I render a scene
2»
  • PerttiA said:
    If you open the pane (tab) called "Scene Info", you can see the number of triangles and quads for the selected item
    Window->Panes (tabs)-> Scene Info
    SubD you will find in Parameters Tab->General->Mesh Resolution
    "View SubD Level" is the one used for Viewport and "Render SubD Level" the one used for rendering
    Did another test with an empty scene.
    First I loaded a simple primitive plane to determine the baseline for RAM and VRAM usage (I'm using W7 - VRAM usage on W10 is higher)
    Then I loaded the Victoria 9 HD character as she comes, with no clothing and hair and rendered her with different SubD levels.
    After SubD 3 the usage of RAM and VRAM start getting higher and significantly so with SubD 5
    SubD 1 is the base geometry, SubD 2 divides each quad into 4 smaller ones, SubD 3 divides each of the quads from SubD 2 into 4 smaller ones etc...
    Rendering simple primitive plane (baseline)
    RAM 6526 MB / VRAM 2735 MB
    Victoria 9 HD, SubD 1
    RAM 10037 MB / VRAM 4329 MB
    Victoria 9 HD, SubD 2
    RAM 10115 MB / VRAM 4357 MB
    Victoria 9 HD, SubD 3
    RAM 10389 MB / VRAM 4475 MB
    Victoria 9 HD, SubD 4 (Default)
    RAM 11508 MB / VRAM 4931 MB
    Victoria 9 HD, SubD 5
    RAM 15981 MB / VRAM 6743 MB
    Useful and relevant information, thank you friend! I didn't know about SubD. This should be useful for me who is struggling with heavy scenes.
  • jjoynerjjoyner Posts: 819
    @luan.yang
    I am a hobbyist at this stuff.  With even more modest resources (16 GB RAM and a 6 GB RTX 2060 card in my laptop) than you, I need to optimize scenes more and more often as I buy more and more recent content.  As a result, I have bought Scene Optimizer as have you but also a few other utilities the help me out with  heavy scene assets as needed.  Principally,
    Resource Shader Savers Collection for Iray: https://www.daz3d.com/resource-saver-shaders-collection-for-iray
    Camera View Optimizer:  https://www.daz3d.com/camera-view-optimizer
    Render Throttle for Iray:  https://www.daz3d.com/render-throttle-for-iray
    Billboard Builder (https://www.daz3d.com/billboard-builder):  Billboards of your characters will lighten the load
    HDR Creator (https://www.daz3d.com/v3d-hdr-creator):  An HDRI in place of a room, landscape, environment, etc., may help
    Instancify:  https://www.daz3d.com/instancify
    Placeholder Manager (https://www.daz3d.com/placeholder-manager):  helps lighten the load on the viewport
  • jjoyner said:
    @luan.yang
    Thanks for the recommendations! I'll take a look at these tools, they might be useful to me in the future when I need to render a very heavy scene. I had purchased Scene Optimizer a few days ago, but it's good to have help from other tools that aim to optimize performance.
    No one tool will be good for all cases or all of the time.  Sometimes a combination of tools gets you to where you want to be.  I'm on the verge of buying a desktop computer that will have more robust hardware resources than my laptop.
