dzneuraymgr.cpp and render canvas's
I dont remember when this intially started,.. so I just stopped using canvas's
but decided to go for it again as I could really use it right now
figured out, Iray is actually writing the canvas's to the temp directory
but failing when writing them to specified directory
2024-03-15 17:43:53.922 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IMAGE:IO ::   1.0   IMAGE  io   error: No image plugin found to handle "E:\SceneFiles\DormDaysTemp\Issue ".
and since I need to do batches of these using RQ it would overwrite with every render any Idea the cause,.. and I know it worked correctly at one point,... it makes the directory for the canvas's but fails to write them there
  • The path to the directory in the log message shows an extra space at the end? Maybe that's your problem?
  • TannimTannim Posts: 46
    It was really something that stupid,... DS can write to spaced directory names no problem,.. but apparently whatever widget in Image.Io thhat writes the EXR's craps the bed if theres a space in the directory name
  • Glad this helped. Maybe you can change the thread's title with a (solved) at the end....
