dzneuraymgr.cpp and render canvas's
I dont remember when this intially started,.. so I just stopped using canvas's
but decided to go for it again as I could really use it right now
figured out, Iray is actually writing the canvas's to the temp directory
but failing when writing them to specified directory
2024-03-15 17:43:53.922 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IMAGE:IO :: 1.0 IMAGE io error: No image plugin found to handle "E:\SceneFiles\DormDaysTemp\Issue ".
and since I need to do batches of these using RQ it would overwrite with every render any Idea the cause,.. and I know it worked correctly at one point,... it makes the directory for the canvas's but fails to write them there
It was really something that stupid,... DS can write to spaced directory names no problem,.. but apparently whatever widget in Image.Io thhat writes the EXR's craps the bed if theres a space in the directory name
