Cannot locate files
Hello,
After purchasing the the Brute8 add on, I used the installer as instructed to download and install the file. However, when I go to open the model , it says it cannot locate files. Other products that I have just purchased have done this as well. After searching the interenet. I tried to locate the files that were missing. After countless searches, I have found nothing. Ive tried to locate the folder in which these files have been installed , but its as if they dont exist. Please advise.
Thank you for your help.
  • frank0314frank0314 Posts: 15,116
    Do you own Brute 8? This is an add-on for that figure.
  • Richard HaseltineRichard Haseltine Posts: 111,972
    The add-on is just the HD details, it uses the shape and textures from the base Brute 8 (though you might be able to apply the details, through the slider in the Shaping or Parametrs panes, on top of another muscular shape to get something usable).
  • Okay, Im a dummy. I only bought the add on, not the brute 8 model. I apologize.
