Genesis 8 female Hip deformation error
I don’t know if a certain deformation product is loaded, which causes the Genesis 8 female’s buttocks to be loaded incorrectly. And Genesis 8 male buttocks loading is normal
I need everyone's help, please help me.
  • neomanneoman Posts: 85
    edited February 2024
    That morph is the "Hip panyhose" in your parameter's tab.  Type in "hip" as a search and you will find it.  Click on the gear and select "reset value".  That should correct the problem.  The bigger question (and I don't know the answer) is why that morph is acting as a default when you load the Genesis base character...
    Does this happen when you are adding a new G8 character to a scene, or when opening the same scene up?  Do you have the "hip pantyhose" morph saved as locked?
    Post edited by neoman on
  • barbultbarbult Posts: 27,636
    It could be the SY Decrackifier.
    Post edited by barbult on
  • 870398416870398416 Posts: 0
    尼奥曼说:
    该变形是参数选项卡中的“臀部连裤袜”。输入“hip”作为搜索,您就会找到它。单击齿轮并选择“重置值”。这应该可以解决问题。更大的问题(我不知道答案)是为什么当您加载创世纪基本角色时该变形会充当默认值......
    当您向场景添加新的 G8 角色或打开同一场景时,是否会发生这种情况?您是否已将“臀部连裤袜”变形保存为锁定状态?
    I'll try it
  • 尼奥曼说:
    我已经解决了,花了好长时间才找到错误的morph产品!
  • 尼奥曼说:
    该变形是参数选项卡中的“臀部连裤袜”。输入“hip”搜索,你就能找到它。单击齿轮并选择“重置值”。这应该可以解决问题。更大的问题(我不知道答案)是为什么当您加载创世纪基本角色时该变形会代替默认值……
    当您向场景添加新的G8角色或打开相同场景时,是否会发生这种情况?您是否已发生将“臀部连裤袜”变形保存为锁定状态?
  • 巴布尔特说:
    它可能是SY Decrackifier。
