Genesis 8 female Hip deformation error
I don’t know if a certain deformation product is loaded, which causes the Genesis 8 female’s buttocks to be loaded incorrectly. And Genesis 8 male buttocks loading is normal
I need everyone's help, please help me.
926 x 1204 - 837K
792 x 1124 - 744K
  • neomanneoman Posts: 85
    edited February 2024
    That morph is the "Hip panyhose" in your parameter's tab.  Type in "hip" as a search and you will find it.  Click on the gear and select "reset value".  That should correct the problem.  The bigger question (and I don't know the answer) is why that morph is acting as a default when you load the Genesis base character...
    Does this happen when you are adding a new G8 character to a scene, or when opening the same scene up?  Do you have the "hip pantyhose" morph saved as locked?
    Post edited by neoman on
    It could be the SY Decrackifier.
    Post edited by barbult on
  • 870398416870398416 Posts: 0
    尼奥曼说:
    该变形是参数选项卡中的“臀部连裤袜”。输入“hip”作为搜索,您就会找到它。单击齿轮并选择“重置值”。这应该可以解决问题。更大的问题(我不知道答案)是为什么当您加载创世纪基本角色时该变形会充当默认值......
    当您向场景添加新的 G8 角色或打开同一场景时,是否会发生这种情况?您是否已将“臀部连裤袜”变形保存为锁定状态?
    I'll try it
  • 尼奥曼说:
    我已经解决了,花了好长时间才找到错误的morph产品!
  • 尼奥曼说:
    该变形是参数选项卡中的“臀部连裤袜”。输入“hip”搜索,你就能找到它。单击齿轮并选择“重置值”。这应该可以解决问题。更大的问题(我不知道答案)是为什么当您加载创世纪基本角色时该变形会代替默认值……
    当您向场景添加新的G8角色或打开相同场景时,是否会发生这种情况?您是否已发生将“臀部连裤袜”变形保存为锁定状态?
  • 巴布尔特说:
    它可能是SY Decrackifier。
