Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
In the event that anyone else is wondering this:
Please know that Anilip delivers the hard part - the speaking lips and jaw.
Emotions can be animated entirely independent from this using expression or other facial dials.
So if you've run Anilp and want to add expressives to the animation, use Expression dials to alter the emotion of the entire face, or the Mouth dials to express only the lips. Eyes dials for eyes, etc.,
Another option would be to look at SimonWM's store for his "Alive" and/or "Expressions and Facial" aniBlock products, where we build these motions along the aniMate 2 timeline.
He's got blinks, double blinks, swallowing... all kinds of fun things to add to any animation - especially speaking ones!
Hope this helps.
Anilip is doing the syncing of the lips and jaw with the text and/or audio, which is Awesome Magic!
I have generated some TTS files via Replica Studios that work as expected, yet after I compiled the lines with desired spacing in DaVinci Resolve and exported them it displays "Unknown: -2147201021" and generates nothing. I'm confident it is merely a settings error on my new files since the original individual files work fine.
Would you be able to provide or direct me to a list of optimal speech recognition file settings? I have seen WAV format and MONO mentioned, but I'm struggling to identify other specifications.
edit: I did a test with just one of the working files and processed it alone through Resolve as WAV / MONO to observe any technical differences. There are some data changes that windows explorer and my audio player (MusicBee) revealed.
Original: 57.6 kb / 22 kHz / 352kbps
Resolve: 126 kb / 48 kHz / 768kbps
The new resolve file gets the same error above. I'm not sure if that extra kHz or kbps is the issue, but, please, let me know if it's important. I'll have to look up where Resolve's setting for that may be as I cannot yet find them.
edit: I did find a few pages back where dobit mentioned this:
DaVinci Resolve shows my original file as:
The only shown difference on the new exported version is the 48000hz sample rate. Unfortunately, I'm reading that my free version of Resolve only does 48kHz (maybe 44.1 too) and even the paid version seems to only go up... I'll keep investigating...
Solved! (I think?)
I'm very confused yet very relieved. I downloaded audacity thinking I'd see if I could convert it to 22kHz. Oddly, I merely exported the not-working files with default settings in audacity and now those work. It's the same Hz, KBPS, and even stereo. I have no idea why that fixed it. It's an extra step, yet fortunately it takes all of two seconds to do. I'm just happy it's working as expected now.
For some reason it seems to partly clip off silence at the end. It's easy enough to correct the full frame number though. I just tried adding the audio files to the playback, and it looks pretty good!
edit: Ah, I think I see about the end trimming. The program registers the dead air at the beginning and throughout as the (.) symbol yet there is none for the end. Curious, but no big problem. I just need to multiply the number of seconds from my original file by the frame rate and reset the timeline after getting the visemes automated.
Hi. I've installed Anilip2 to a Windows 10 PC and added the serial number to the plugin under Help in Daz Studio 4.22. I don't see anything besides the intro video in Daz Studio. Three files show up as installed in DAZ IM. I can see dobitanilip2 files under program files / DAZ 3D / DazStudio4 / plugins. Any suggestions?
This literally sets the timeline to only one frame. It affects all characters and not just the character you have selected. Further, if you reset the number of frames back, the animation is still there.
Where are the keyframes, anyhow? For Genesis 9, I see no keyframes on the timelline, so there is nothing I can delete manaully. If I do [Ctl]-[A] to select the Viseme rows and delete them, the character's mouth still moves when playing the timeline even after saving to the timeline.
In short, I see no way to clear the mouth movements without starting the scene over.
Hey anyone out there. Is there a way to start Anilip on a specific frame in animate 2?
Hey never mind. I found something to help me.
Hello! I have a question about speech recognition. If the phonemes recognized are not the correct ones, how can I edit them and generate correct visemes?
Also a comment - having standard IPA notation for the phonemes helps a LOT. It's unambiguous!
Nevermind. I found it :-) Now it's just working out the timing for missed phonemes. Probably if my sound recording was better, it wouldn't miss phonemes. :-)
You can edit any phoneme in standard IPA notation, X-SAMPA, ARPABET or Microsoft UPS. You can add or remove phonemes, but you have to adjust the timing.
The tutorial videos and the manual give some hints.
Hi, I got anilip 2 some time ago and am just now trying to get it to work. you mention above the tutorial videos but when I click on them in the anilip 2 hints tab it links to a video error message that says:
Video unavailable
Playback on other websites has been disabled by the video owner
Watch on YouTube
this link does not work. Can you please re-enable the videos so people can learn the software.
my other question is about the upgrade price for upgrading to anilip 3.
thanks!
wow thats funny! the link I copied and pasted works! weird...
Video links should work / work in my installations. Which browser do you use?
There is no special upgrade price. However, Daz has regular promotions with some very good discounts.
thanks I guess it was an internet issue. I only asked because the error said you had taken down the video but I later got the link to work..
Hi there,
I just bought Anilip2 and am trying to use it with a G8F figure. It started with a custom character but has now switched to the basic G8F.
ATM, I don't have a Speech Recognition tab in the Settings. Secondly, I can't get any animation from it. Both speech recognition and text-to-speech generate sets of visemes in Viseme Animation and add stuff to the timeline, and I can move the slider to see that Anilip2 moves along the visemes, but that's it. The character isn't animated.
Am I missing something?
There are no special settings for speech recognition. Anilip2 only generates visemes, no other animations. For Genesis 9, Dobit offers Anilip3 and some complementary pose and animation products for creating dialogues.
By animation, here, I mean the visemes. In other words, I only get the viseme list in the Anilip2 tab, but the character doesn't move her lips/mouth at all.
Gen9 is a no-go for me, so let's keep it off the tab for the time being.
Disregard my posts here.
I reinstalled Anilip2, and it is working as expected. Apologies for the false alarm.
Hello again :)
I can't find a way to "cut in" the Anilip animation to an existing timeline. Is there a way to do it?
For example, I have a scene where two characters are having a conversation. They're somewhat animated, and want to anilip them both in sequence, one after another, in the same timeline/scene. Can I do it with Anilip2?
Also, I have a 7-second-long file with speech, but Anilip2 only recognizes around the first 3 seconds and gives me 30 visemes even if I copy the text to the Transcript field.
I'm confused :( How can I improve/fix this?
I would apologize for flooding the thread with messages, but now I'm massively curious. It's almost personal now.
So, I tried to cut the "problematic" recording into two parts, right where the non-recognition happens. Now, when I'm loading the first part of that recording to Anilip2, it doesn't give me 30 visemes like it did before; it gives me only 16 of them, which is roughly half of the first part. So I have a new "non-recognition" place in the recording where everything was more or less OK before.
I'm suspecting the accent in the recording might be an issue here, but accents are usually not a problem for lip-sync solutions (unless the accent is extremely terrible). And the character is accented by design, so recording a "cleaner" version isn't exactly a good idea.
Still, the problem exists, and I'd really like to get some help with it.
