• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
How could I have DAZ Hair Strands converting to Blender?
elatik7elatik7 Posts: 2
February 2024 in Blender Discussion
I wanna use a certain hair I found but it would seem its an actual simulation, I don't have much experience with DAZ so Im looking for a way to get this imported to Blender
In Blender it only gives me curves.
  • PadonePadone Posts: 4,008
    February 2024
    With diffeomorphic you can convert polylines to strands or particles, as well as import or convert transmapped hair.
    https://bitbucket.org/Diffeomorphic/import_daz/wiki/Setup/Hair
  • elatik7elatik7 Posts: 2
    February 2024
    Nothing worked here, guides weren't helpful for me. Could you please elaborate more? If it helps im using the Manami Hair for 8.1
  • lilweeplilweep Posts: 2,746
    February 2024
    wouldnt it be more efficient to describe what part of the process was difficult for you than asking people to write a whole new guide explaining every possible aspect you may or may not understand?
    February 2024
    I literally just said that the guides didn't work out for me. As I followed it step by step and still not get anywhere from the first images.
    February 2024
    if you followed step by step you would know which step failed no?
    February 2024
    No because Im still stuck on the same problem and none of the steps have helped me
    February 2024
    To be fair, diffeomorphic's wiki and guides are fairly awkward and deficient.
    As is their website. I briefly mentioned this before in the diffeo thread: not even having an intro on the landing page of the website explaining what the plugin is and what it does seems like a massive fail missed opportunity. Plus, if you read through any documentation, it often reads more like a github thread than a wiki/guide, often referring to a nesting doll of several previous posts to get the full story instead of just having current info summarised succinctly.
    Also specifically in the hair section of the wiki, they say to export SBH at Render Line Tesselation = 2, then much later say they can import PS guides from the duf file, and then later suggest to export in dbz at Render Line Tesselation = 0.  There is way too much extraneous conflicting info - it should just be a table or list of what the options are for SBH: PS Guides, export as polyline, export as mesh, etc with pro/con, and methodology.  The guide also refers to images without stating which specific image they refer to, whether the image is above or below text, or referencing a figure number.
    Great plugin though - they should keep up the good work in that respect!
    February 2024
    @lilweep The added notes in the wiki are mine, I don't want to modify the original documentation by Thomas so I add notes at the end when in my opinion there's something important to add or update. Then I admit I'm not great with docs nor they are my main interest with the addon, it's just an attempt to help.
    @elatik7 Exactly what is it that doesn't work and what's the error message ?
    February 2024
    I exactly follow the guide to export SBH to Blender but they still remain mesh curves and they aren't layered in eachother like it showed on the guide, they're still single curves in Blender.
    February 2024
    Yes of course, after importing you need to convert them as a separate step, using the make hair tool.
    https://bitbucket.org/Diffeomorphic/import_daz/wiki/Setup/Hair/Make Hair
    February 2024
    Yup thats what I missed lol. I used the Tube and Particle output, but now the question is.. if I use this model for 3D rendering, how will I move the hair in certain positions? Like if she would bob her head sideways that I also position the hair towards that direction/gravity? Because with normal hair cards meshes I just use the sculpt tool but this is different
    1270 x 1287 - 321K
    February 2024
    It depends on the hair. For rigged hair you can use in blender the same extra bones you have in daz. For dforce hair you will have to use simulation in blender, that's possible for particles hair with some limitations, and not possible with curves hair yet, unless you use a complex node setup. These are blender limitations and beyond the purpose of the addon, you may find better help on this topic on a specific blender forum as blender artists for example.
    As you noted yourself, at the time being in blender it is much easier to animate hair cards than particles or curves. Luckily you can always convert to cards with: object > convert > mesh.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
