MEC4D's celebration ( with freebies ) [commercial]
1252628303184
  • PendraiaPendraia Posts: 3,627
    MEC4D said:
    +1 Richard , especially with G3 angry
    RAMWolff said:
    MEC4D said:
    The joys of rigging and weight mapping!  cheeky
    Too true...have you any idea what causes an item to shrink when weightmapped? I tried doing a skirt for her and it shrank...
    Your suit sounds fantastic...I would imagine it requires some very good morphs and rigging.
  • JennKJennK Posts: 834
    edited July 2015
    My first render with the wonderful clothes. Thank you Cath and Happy Birthday!!!
    Post edited by JennK on
  • MEC4DMEC4D Posts: 5,249
    Not for nothing we say someone looks sharp in a suit  ..but the rigging is really the secret here to get it right and so far tests looks great ..just taking my time with it
    barbult said:
    MEC4D said:
    Suit is not a dress and since it is my first suit I want it to be perfect like no other you ever used, I want to make sure it move-bend like a suit too  , it is new setup I am doing and different from what you used ever before so I am testing stuff out , free or not I can't release a crappy set wink I don't have issues just trying to setup it the way so it pose dynamic automatically like a real fabric .. for example when you bend the arms wrinkle show up automatic ..I could add that with normal maps but then the suit looks wrinkled all the time .. not really what I am looking for .. so another step forward with the 3D evolution for me
    DanaTA said:
    @Mec4D, how is the work going on the Miami Vice suits?  I seem to remember you said something about a problem.  Did you solve it?  I hope it isn't too much trouble for you...after all, you're giving this stuff away!
    Dana
    Oh, that sounds real exciting! I've skipped some of the other suits because of their doughy, rounded, puffy appearance. A well tailored suit is crisp and angular. I'm looking forward to seeing how you're pushing the technology forward. yes
    If you model the skirt on a character and not base genesis you need to use reverse deformation while rigging other way it will change the scale or shape you find it under Transfer Utility , also if the skirt model was adjusted in DS before rigging it will change back to original position .
    Thank you very much ! that is a nice one ! actually had dress like that in black it was finished with a top short bolero  , imagine to go on the street dressed like that today, they would think I got little  kaka winklol
    It was modeled and fitted in ZBrush...sent via the bridge and fitted when it loaded in DS. When I used the transfer utility it shrank...I haven't had this problem with things previously. So I wasn't sure if it was something new due to the new rigging. Or something I need to do in terms of modeling for Gen3...
    I never had problem like that before , but it maybe have to do with the skirt template under Transfer Utility and the topology of your skirt , if this problem persist , after rigging send both genesis and skirt back to Zbrush via GOZ  (send with deformation ) fix the poke of the skirt in Zbrush and send it back to DS and at import choice (Update Geometry only ) it will replace the old , after that you can save the new skirt and problem solved .
    If you model on V7 make sure the reverse deformation is selected under Transfer Utility  , also model clothing for genesis base only never on subdivided genesis or it will not fit .
  • magicweavermagicweaver Posts: 254
    happy birthday and thank you! *hugs n slobbers*
    Thanks for the help Cath! I'm wondering whether I remembered to lower genesis to the base level, that might be what happened. I'm pretty good about remembering to do it for morphs but wouldn't have thought about it for clothing.
  • DarkSpartanDarkSpartan Posts: 1,096
    edited July 2015
    Carrara and I finally decided on a design, so... First peeks!
    I'll model a belt and a clip on the back of the device for Genesis 3 before I run this out to folks. The question will end up being how detailed the mesh will be as opposed to displacement. I'm a lot better at modeloing than I am at mapping, so finding the balance will be the important bit.
    Also, what features should there be? Radio? EQ? Other random fun?
    Post edited by DarkSpartan on
  • DanaTADanaTA Posts: 13,361
    Dana
    Oh, believe me, I am not trying to rush you!  It's amazing the things you are thinking of for this suit.  Other modelers will be jealous of your creation!  I just was afraid that I missed it or you gave up on it.
    Dana
    Did you wash it in digital hot water?   laugh
    Dana
  • kyoto kidkyoto kid Posts: 42,088
    ..hmm, isn't the workout clothing for G2F?
    edited July 2015
    Yes, yes it is.
    But that outfit already has spots that one can parent the device to so she can wear it while she's running or biking-- which are the most common times to use one. During aerobics, especially the high-impact variety, there's too much chance it's going to get damaged. wink
  • thnk u so much for the gift and hope u had a great birthday xx
    Thank you ! Hugs back !
  • scathascatha Posts: 756
    Cath, but this is exactly one of the reasons we love you (and your work), you're a perfectionist at heart and nothing that ever gets released can be called half-arsed.  ;)
  • ModernWizardModernWizard Posts: 904
    DarkSpartan -- I suggest a window to show the tape inside!
    --MW
    --MW
    All the early ones had that, after all... It'll require some spiffy texture work, though, as the idea of modeling the interior of one of those things in its entirety from memory is rather... Daunting. Right now, I'm trying to get the mesh assembled in such a way that it has a door.
    Although just by saying that, I've dated myself rather badly.
    --MW
    Oh God, all those little pins and moving parts. Blech. Maybe it would just be easier to add a window [material zone?] on the door and then tell users that, if they want to put a tape inside, they could download one, then scale it and position it. Squealing and griding noise when the rewind gets to the end of the tape not included. :p
    Are you planning to make just the tape player, or are you including the el cheapo headphones with very thin foam covering too? No pressure...I'm just curious because I remember how uncomfortable they were and how I always ended up purchasing a lrger and more padded pair of headphones that didn't pinch my ears.
    --MW
  • RLSprouseRLSprouse Posts: 288
    Thank you so much, Cath!  And happy birthday to you!
    Warm regards,
      ~ Russ
  • Eustace ScrubbEustace Scrubb Posts: 2,730
    Dana
    Well, now!  With that kind of commitment to quality I'm tempted to insist that you put it in the store in stead of here, so I can pay you for it properly!  Nothing says 3Derp quite the way tissue-tube trouser legs do, and properly bending and wrinkling pants are hard to find!
  • CitizenMCitizenM Posts: 39
    Happy Belated Birthday! I hope it was wonderful. I just saw this post in the nick of time.
  • SimonJMSimonJM Posts: 6,081
    I dunno, ANY trousers I put on, wrinkle! ;)
  • GreywulfGreywulf Posts: 58
    Cath you're beautiful inside and out, as well as one the most talented and professional people I've ever had the pleasure to know. Thank you for all that you do and all that you are.
    Every day should be your birthday :)
  • Testing6790Testing6790 Posts: 1,091
    Happy birthday! 15 years a PA, wow, that means you've been here from the beginning!
    Thank you guys ! +1
    Warm regards,
      ~ Russ
    Dana
    Finally a mermaid ! love it , thanks for sharing !
  • MBuschMBusch Posts: 547
    edited July 2015
    Waiting for you boys
    Let's dance
    I put my pink shoes to dance the blues
    Let's dance
    To the song they're playin' on the radio
    Post edited by MBusch on
    --MW
    --MW
    That depends. If I want to be annoying, I can point people to Valandar's Headphones kit in the store. Making the headset wouldn't be that difficult, nor the 3/8ths plug... The bit in between will be a major pain to get rigged.
    @MBush awwww so pretty ! love the little details and sharpness ..thank you for sharing , it was worth waiting !
    Let's dance
    Let's dance
