[Released] RSSY Hair Converter from Genesis 8 to Genesis 9 [Commercial]
1…468910
  • barbultbarbult Posts: 27,612
    edited October 2023
    I converted Primavera Hair (the hair shown in your product main promo, I believe). The geoshells that were part of the original G8 hair appear to have been lost during conversion. I converted with Extra Long conformer, since Primavera is very long. It also ended up with a big gap at the top of the head, like what happened with Kala hair when I converted with the Short comformer. If I convert with the Normal hair conformer, there is not big gap at the top of the head (but geoshells are still lost). Of course when I convert with the Normal Hair conformer, I don't get the long hair bones. So. there is not good conformer choice answer here. Please investigate why the short and extra log conformers cause the top of the head gap.
    1413 x 1418 - 375K
    Post edited by barbult on
    If you're getting better result with AutoFit, you might be better off returning the product rather than suffering more frustration. It's not that we don't want to help, it's that I literally don't have the same problem. I didn't do some weird magic trick with Primavera hair for the promo, I'm pretty sure I just converted it with the Regular conformer and used it without the geoshells. It's almost never worth using anything but the Regular conformer with dForce hair because dForce hair seldom has "real" geometry, it's grown as procedural type strands off a cap. There are a few hairs by for e.g. AprilYSH that have dForce and movement morphs, but they are the exception, not the rule. I would swear the manual does say this.
    Thank you for responding, SickleYield. Primavera Hair is a Linday polygonal geometry cloth-based dForce hair. It is not strand-based dForce hair. The Swept Wetlook Hair is regular OOT hair, not dForce at all. I am a fan of RiverSoftArt and SickleYield products and own a lot of them. This converter is very convenient and has excellent features, like setting the metadata and creating a product from the conversion. I was hoping that the converted results could be improved, by offering specific examples of things that don't work as expected. But if you don't experience the same issues, I see that my examples don't help.
    If you have access to another clean DS on another system or in a VM, you could convert it also in there (to avoid whatever is borking it up).  Then you copy the results back to your main DS (where you already converted it so you have nice metadata) and see if that cleans it up.
    I can try to install it on my husband's computer some time when he is not using it. Thanks for the suggestion.
    You're welcome!
    My husband was on a business trip last week, so I was able to use his computer. I installed DS, Genesis 8 and 9 starter essentials, and a few G8 hairs. Unfortunately the converter behaves the same on his computer as it does on mine. For example, when I convert Winfield's Karla Hair with the Short Hair conformer, there is a big bald spot on top of her head. With the Regular Hair conformer it works OK. I don't know why you and SickleYield don't see the same issues. Anyway, I guess it is what it is. I'll use it for what it can do and use other methods for what it can't do.
    I hope he doesn't mind Genesis 8 and 9 traipsing over his computer laugh
    No, I had his permission to do it. I chose well 48 years ago!
    I am sorry that we can't see and fix your issue. sad (And happy for you that you have another reason to be happy about your decision 48 years ago.  Congratulations smiley)
    Thanks for your good wishes. smiley
  • Exactly the same issue a others here.
    I must admit I'm a bit tired of all the bugs with the different converters (character, hair... nothing works as expected). Sorry, I don't want to be rude, of course, just tired :) I'm just now wondering if I really want to change to G9 char xD
    996 x 778 - 717K
    We are trying to figure something out....
    While we wait for RSA to figure something out, one could use this tutorial to fit G8 hair to G9. It works quite well, even for non-poseable hair
  • What have I done wrong? If I choose the directry everything is skipped and when I do files individually it cant find the files. What can I do to fix this?
    1327 x 874 - 162K
    For the first one (Twin Buns), I would need the Daz Log to say more but it looks like it cannot find the preset (as if it has been deleted).  The next conversion you try is on a MATERIAL, and of course, this does not work.
  • Submitted an update today:
    • Improved Hair Conversion Method supporting more hair types
    • Improved conversion morphs
    • Changed Search behavior to a filter behavior
    • Changed Select Conformer dialog to use radio buttons
    • Fixed Edit Content Type Conformer dialog
    • Fixed dialog to select Beard conformer for Facial hair
    • Updated Manual
    • Updated Manual
    Thank you, I assume hair's like Voltya hair are now conversion quality?
    • Updated Manual
    Sorry, I do not have a Voltya hair to check if it converts properly
    • Updated Manual
    Derp, VOLTA Hair.
    Its a hair that sliiightly curls back and so the converter thinks the curl part should stay in the air.
    • Updated Manual
    Derp, VOLTA Hair.
    It converts Volta Hair, which doesn't seem to have many morphs, but looks good to me:
    512 x 512 - 276K
    • Updated Manual
    Derp, VOLTA Hair.
    Does it warp if you pose the figure? Because that was my issue.
    • Updated Manual
    Derp, VOLTA Hair.
    In that screenshot, I twisted and bent the neck/head.  I didn't see any warp.  I didn't do any other pose though.
    • Updated Manual
    Derp, VOLTA Hair.
     This is the type of deformation I've seen.
    574 x 591 - 71K
  • Eboshijaana said:
    • Updated Manual
    Derp, VOLTA Hair.
    Not seeing it smiley
    1335 x 1374 - 174K
    Eboshijaana said:
    • Updated Manual
    Derp, VOLTA Hair.
    Welp, time to reconvert the hair then! Or are you using the updated script?
  • Eboshijaana said:
    RiverSoftArt said:
    Eboshijaana said:
    • Updated Manual
    Derp, VOLTA Hair.
    You will have to wait until the update is out (it is in Daz's hands).  Make sure you delete the data folder of the hair before reconverting.  The new method is not forgiving when converting something twice.
    edited February 2024
    I'm using DS 4.22.1.74 Public Build. Yes, I see tha same kind of deformation. This is with the original version of the converter. The update is not in DIM yet.
    Volta dforce hair has bones. The converted hair does not move those bones with the hair when the character is posed.
    If I simulate the hair from memorized pose, those bones seem to be ignored and the hair simulates pretty well.
    1413 x 761 - 180K
    1425 x 828 - 201K
    1247 x 751 - 132K
    The update is in DIM now. I installed it. I deleted the old converted data folder and the folder with the duf file. I converted Volta hair for G8M with the Normal Regular Hair conformer. It looks good in the viewport. It no longer gets stuck when posing the character's spine (bend twist side-side). smileyHowever, it won't simulate now. sadWhen I try to run the dForce simulation, it always displays an error and does nothing.
    1396 x 1329 - 301K
    581 x 1225 - 129K
    I converted Ezra hair, which I had never converted before. It won't simulate after conversion either. Is dForce simulation of converted hair broken in the updated script?
    The Ezra Hair for G8M still simulates fine on G8M, so it is not a problem of my computer not being able to simulate dForce Hair.
    813 x 1001 - 133K
