Show Us Your Iray Renders. Part IV
12021232526100
  • MattymanxMattymanx Posts: 6,997
    Pixel Filter set at ZERO.
    Beautiful image! Could you share your setup for the render? Love the toon/pixar look, that's what I'm aiming for.
    Ok, there is a single EXR file, from Luminance Kit #2 from "Augmented Reality Lighting Compilation" from DimensionTheory
    Thats a really cute character.
    Think twice when you say "Aiko3 is obsolete"
    not in my Runtime!
    I let her go finally last year. Been just over a year to be honest
  • nDelphinDelphi Posts: 1,922
    I am still working on photoreal renders, this one is the Lucy Angel Statue. Scanned in 1998 by the Stanford University Computer Graphics Laboratory. This is the best mesh I was able to find.
    I like it when they look real.
    900 x 900 - 92K
    900 x 900 - 58K
  • HavosHavos Posts: 5,595
    They look very nice, but to look real I suspect they would need to look at least a bit dirty, rather than brillant white. Only takes a few defecating pigeons to change the look of a statue.
    Yeah, you're right. I should dirty them up a bit.
  • DustRiderDustRider Posts: 2,888
    Thanks to the thread about Iray being for “realism”, I got inspired to do a toon render in Iray. I used Genesis (1), the character is a combination of The Girl 4 and Nata, and uses the texture set that comes with Nata. Almost all of the shaders are customized Iray shaders using the Iray uber base as a starting point (except for the bikini and shoes which are the Silk - Blue shader). The background is the Classic Deco set, lit with 3 mesh lights.
    As usual, best viewed at full 1600 x 2000 resolution - the hair came out extremely good IMHO.
    1600 x 2000 - 479K
    Don't tell me there is controversy over that as well? LOL! Because according to NVIDIA:
    "NVIDIA Iray is a state of the art, yet easy to use, photorealistic rendering solution..."
    But I guess you can use for anything you want.
  • ShawnBoothShawnBooth Posts: 465
    Playing with a Prototype and Mec4D's Shaders...
    1414 x 2000 - 480K
    Really well done!
    (Looks like a "real" cartoon :)
    I guess it all depends on what you want to make look "real". I try to shoot for realistic 3D, meaning everything looks like a true 3D object. Iray is great for that!
    Really well done!
    Thanks!!!
    Well said.
    That's really impressive at full resolution!!
    Thanks! I just lit it and played with shaders. Stonemason and Mec4D did all the hard work I have yet to learn how to.
    I like the first one more.
    In the second (with clouds), I feel the clouds distract from the statue and the tree pulls my eye away. What are your camera (tone mapping) settings? Maybe stop down? (Close the iris a stop - if you're at a 11, go to 16). Shaders used on her?
    edited July 2015
    No, there is no depending. I just read that thread and zilvergrafix and Snowsultan made the best case. Photorealism is the act of getting close to real. It seems some wanted to make it into a philosophical debate. I will not go down that path. Photoreal has a meaning and no amount of debate is going to change that. All the NVIDIA videos I saw on the development of iRay pointed to how real they wanted the end the results to be. They never used the words it "depends", or styles, or whatever.
    Post edited by nDelphi on
    I actually liked the strong lighting on the second one. Although the first is what I was working towards. I used the same shader settings I used here:
    http://www.daz3d.com/forums/discussion/57355/P495/#844164
    I just need to dirty up the shaders a bit on the statue and I am sure I'll get there.
  • j cadej cade Posts: 2,310
    edited July 2015
    No, there is no depending. I just read that thread and zilvergrafix and Snowsultan made the best case. Photorealism is the act of getting close to real. It seems some wanted to make it into a philosophical debate. I will not go down that path. Photoreal has a meaning and no amount of debate is going to change that. All the NVIDIA videos I saw on the development of iRay pointed to how real they wanted the end the results to be. They never used the words it "depends., or styles, or whatever.
    That was me! No arguments on photorealism though, that means "like a photo" Realism is vague it has meant a lot of things, photorealism is pretty simple.
    On your 2 images, I like the lighting on the 2nd one too, but it doesn't seem to mach the background to me, as the highlight of the statue is much brighter than the clouds, makes them feel disconnected
    Post edited by j cade on
    edited July 2015
    LOL! I guess I should use the words real and be done with it. Eh, who cares anyways, lets just have fun.
    That was just me messing with the lights, it looked cool so I thought I post it, too. It looks like some kind of divine sunlight hit the statute.
    Here's a non-real render I did. I was experimenting with the diamond shader.
    900 x 900 - 289K
    Strong lighting will still be there if you stop down. IMO, it looks overexposed.
  • StevieCStevieC Posts: 70
    FYI, for those who don't have a powerful PC, (like me), and who, perhaps, have had Daz crash while trying to launch a complicated scene, just discovered that when I switch to Nvidia iRay in Drawstyle and let it continue to run, it continues to iterate, and if I let it run for several hours, I get a finished image as good as if I tried to actually render it. I checked the log, and , although I couldn't get a Printscreen of that, it states that it is still iterating. (Not sure if that's the correct term). I took a Printscreen of that, and compared it to a Render that finished at 7 hours. Below are the two images. The one with the less glossy water pane is the actual Render, the one with the glossy water plane is the Printscreen of the Drawstyle viewport left open and running for about 4-5 hours. The actual Render is 1006x566 at 297kb, and the Drawstyle image is 1003x531 at 279kb......go figure! Now t least I know I can still get a "Render" if it crashes when I try to actually render it, if that makes sense.....
    1003 x 531 - 279K
    1006 x 566 - 298K
  • ZilvergrafixZilvergrafix Posts: 1,385
    Bloom filter, Vignetting, Depth of Field on camera, Emitters, HDR, even MS Paint for postproduction...
    1467 x 896 - 288K
  • kyoto kidkyoto kid Posts: 41,931
    ...bugger, been .too hot to do any rendering where I am. Was 101° in the neighbourhood today and been in the mid to upper 90s all week. Core temps running 10° - 12° higher then normal. Even at night time it's too warm. Not much change in store until the end of next week.
    Too much bloom perhaps? It's a bit distracting.
    Would be cool to see them making eye contact...
  • Teddy GTeddy G Posts: 23
    G2F with a G3F morph courtesy of Transfer Utility and some of the European morphs from V4 Ethnic Faces.
    459 x 585 - 437K
  • WilmapWilmap Posts: 2,917
    Here's a render of the new Skylar figure using an HDRI Dome.
    600 x 776 - 860K
  • VisuimagVisuimag Posts: 578
    A timid little swimmer.
    1908 x 919 - 170K
    Another of Skylar
    600 x 776 - 753K
  • ArtiniArtini Posts: 10,343
    tjohn said:
    Impractical Armour
    V6 HD with Macro Skin converted to Iray with the G2F Optimizer.
    Where did you found the G2F Optimizer?
    Could you please provide a link for it.
  • TJohnTJohn Posts: 11,339
    Artini said:
    tjohn said:
    Impractical Armour
    People>Genesis 2 Female>Materials>Iray
