Fitting G2F clothes on G2M in Poser?
Upirium
In Genesis2 figures or whatever it says that female clothes should be able to fit on males and vice versa for ...idk, etc etc.
But I seem to find it's kind of hard to get it to work.
I have to do a lot of fiddling...
and it's not quite as easy with the gen4 figures because I can't scale them in x/y/z directions there seems to only be one scale in certain areas.
This is what I managed to do but is there an easier way?
Have you tried the Fitting Room?
No, I don't really like it. It warps the bottoms of things and really takes up a lot of memory to do, and kind of overheats my comp.
There are scripts to unhide hidden dials, if that's the issue.
I don't know if that will help but i'll try it.
You could always auto fit using DS, then Save As->Support Asset->Figure/Prop Assets. After that you should have a version that will fit G2M in Poser.
Below is the result of me auto fitting a G2F outfit in DS (http://www.daz3d.com/ranger-outfit-for-genesis-2-female-s) to G2M, and then using that in Poser. The render was done in Poser. A pretty good fit, I think.
