Fitting G2F clothes on G2M in Poser?
UpiriumUpirium Posts: 727
In Genesis2 figures or whatever it says that female clothes should be able to fit on males and vice versa for ...idk, etc etc.
But I seem to find it's kind of hard to get it to work.
I have to do a lot of fiddling...
and it's not quite as easy with the gen4 figures because I can't scale them in x/y/z directions there seems to only be one scale in certain areas.
This is what I managed to do but is there an easier way?
  • fixmypcmikefixmypcmike Posts: 19,710
    Have you tried the Fitting Room?
  • UpiriumUpirium Posts: 727
    No, I don't really like it. It warps the bottoms of things and really takes up a lot of memory to do, and kind of overheats my comp.
    There are scripts to unhide hidden dials, if that's the issue.
    I don't know if that will help but i'll try it.
  • HavosHavos Posts: 5,636
    You could always auto fit using DS, then Save As->Support Asset->Figure/Prop Assets. After that you should have a version that will fit G2M in Poser.
    Below is the result of me auto fitting a G2F outfit in DS (http://www.daz3d.com/ranger-outfit-for-genesis-2-female-s) to G2M, and then using that in Poser. The render was done in Poser. A pretty good fit, I think.
    1387 x 822 - 179K
