Daz Studio 4.23(.0.x) - NVIDIA Iray
rbtwhiz
When a new build of Daz Studio includes a new version of the NVIDIA Iray renderer, the new build of the renderer comes with its own set of bug fixes, new features, adjustments to existing features, etc. Since the release of Daz Studio that followed the initial introduction of NVIDIA Iray in Daz Studio (4.8 - initial introduction, 4.9 - following release), a list of its changes have typically been made available in the posts that immediately follow the announcement. In many cases, while the information contained within the posts was/is useful to those that want/need it, it seemed to go unread by many. This same information would also then be reposted when a Public Build was eventually promoted to General Release.
To address some of these issues and bring more visibility to the changes for those who want/need it, we now split these posts off into their own thread. A separate discussion thread will remain available (linked below), but the thread itself will be closed for comment so as to avoid the information being buried by the discussion and to provide notification through regular features of the forum software.
*Note: The entries below come directly from the NVIDIA Iray release notes. Some entries, such as the mention of Linux, Python, etc, currently have no bearing on Daz Studio itself but are included for completeness.
Public Build (Beta) Threads:
- 4.23.0.4 (October 10, 2024)
- 4.23.0.3 (October 9, 2024)
- 4.23.0.1 (October 7, 2024)
- 4.22.1.228 (October 4, 2024)
- 4.22.1.224 (September 27, 2024)
- 4.22.1.221 (September 23, 2024)
- 4.22.1.202 (September 6, 2024)
- 4.22.1.161 (June 26, 2024)
- 4.22.1.154 (June 17, 2024)
- 4.22.1.150 (June 4, 2024)
- 4.22.1.136 (May 3, 2024)
- 4.22.1.123 (April 12, 2024)
- 4.22.1.110 (March 26, 2024)
- 4.22.1.99 (March 6, 2024)
- 4.22.1.88 (February 21, 2024)
- 4.22.1.74 (February 2, 2024)
- 4.22.1.58 (January 16, 2024)
- 4.22.1.54 (January 10, 2024)
- 4.22.1.41 (December 22, 2023)
General Release Thread:
- 4.22.0.19 (September 16, 2024)
- 4.22.0.16 (February 27, 2024)
- 4.22.0.15 (December 20, 2023)
- 4.22.0.1 (November 1, 2023)
- 4.21.0.5 (October 12, 2022)
Previous Thread:
Iray 2023.0.0 beta, build 367100.1652
Known Issues and Restrictions
Added and Changed Features
- Add core support for the new MDL 1.8 features
- Added support for "An Analytic BRDF for Materials with Spherical Lambertian Scatterers" (
- Added support for
Iray Photorealdf::dusty_diffuse_reflection_bsdf).df::thin_filmmodification ofdf::custom_curve_layeranddf::directional_factor.unicode identifiers.light_profileandbsdf_measurementhave no members.unary_expressiontoassignment_expressionsfor the expression affected by the variables. This ensures the right scope precedence, e.g., the let-expression ends at a sequence operator.import_path,qualified_importto allow Unicode identifiers in package and module names.anno::in_groupstandard annotation to control the UI presentation of groups.node_output_port_defaultand the respective enumeration typenode_port_modeto control the default initialization of output ports for external shade graph nodes when they are created for MDL functions.noinlineto hint that a function or material should not be inlined by the compiler.state::texture_spaceand the related tangent state functions return the zero vector in case the index is out of the range of available texture spaces.math::smoothstepand that it is undefined for a zero or reversed interpolation range.float4x4as supported data type for scene data lookup.custom_curve_layeranddirectional_factoras eligible base BSDF for thethin_filmBSDF modifier.measured_factormodifier BSDF allows reflectivities above one and it is in the responsibility of a material author to ensure energy conservation.parameter_list,argument_list,enum_type_declarationandannotation_block.base::abbe_number_ior.base::coordinate_projection()to reduce size of generated GPU code.mi::neuraylib::IMdl_backend::execute_init()method to allow calling init functions in single-init mode for the native backend.in_group annotation(collapsed).in_group$1.7" annotation.in_group annotation(collapsed).in_group$1.7" annotation.ICompiled_material::lookup_sub_ expression(),IMdl_distiller_api::create_baker(), various methods onIMdl_backendand theTarget_function_descriptionstruct. Hardcoded paths need to be adapted. A frequently occurring pattern is ".components.<number>." which needs to be changed to ".components.value<numner>.".DS_SEQUENCEfrommi::neuraylib::IFunction_definition::Semantics.IImage::set_from_canvas(), andIImage_api::create_canvas_from_buffer(), andIImage_api::create_canvas_from_reader(). The old signatures are deprecated. They are still available ifMI_NEURAYLIB_DEPRECATED_14_0is defined.create_texture(),create_light_profile(), andcreate_bsdf_measurement()onIMdl_factoryhave been changed: These methods take now aIMdl_execution_contextpointer as last argument instead of the optionalmi::Sint32pointer. The old signatures are deprecated. They are still available ifMI_NEURAYLIB_DEPRECATED_14_0is defined.IImage::create_mipmaps()has been renamed toIImage::create_mipmap(). The old name is deprecated. It is still available ifMI_NEURAYLIB_DEPRECATED_14_0is defined.IImage_pluginhas been changed to allow selector support and better plugin selection (See the API reference documentation for details):supports_selectors()has been added.open_for_reading()has an additional parameter for the selector string.test()method takes now a reader instead of a buffer and the file size.df::dusty_diffuse_reflection_bsdf.df::thin_filmmodification ofdf::directional_factoranddf::(color_)custom_curve_layer(MDL-1048).df::thin_film()where the base BSDF is identical to the BSDF of the other case of the ternary.enable_pdf" backend option to allow disabling code generation of PDF methods for distribution functions.mdl_next" option. Especially the following features were added:scene::lookup_data_float4x4().anno::native(),anno::node_output_port_default().mdl_next" option is currently a no-op.Fixed Bugs
meters_per_scene_unitin MDL-JIT compiled volume materials, and in general fix several issues related to this.in' in the 'let' expressions, leading to a compiler error and resulting in that only unary type of expressions could be parsed correctlydf::scatter_transmitmode.df::thin_filmwith a thickness of zero, independent of the IOR value.df::thin_film()handling for PTX backend.Iray 2023.0.0, build 367100.2992
df::fog_vdf).fog_vdf.particle_sizeparameter of the newfog_vdfapproximative Mie VDF model refers to the particle diameter.ILink_unit::add_environment(). UseILink_unit::add_function()withILink_unit::FEC_ENVIRONMENTas second parameter instead. The old method is still available ifMI_NEURAYLIB_DEPRECATED_14_0is defined.IExpression, in particularIExpression_temporaryandExpression_parameter.Argument_editor::set_value()andget_value()allow now to set or get entire arrays in one call.mi::neuraylib::IImage::reset_file()mi::neuraylib::IImage::reset_reader(IReader*,...)mi::neuraylib::IImage::reset_reader(IArray*,...)mi::neuraylib::ILightprofile::reset_file()mi::neuraylib::ILightprofile::reset_reader()mi::neuraylib::IBsdf_measurement::reset_file()mi::neuraylib::IBsdf_measurement::reset_reader()mi::neuraylib::IVolume_data::reset_file()mi::neuraylib::IVolume_data::reset_reader()mi::neuraylib::IMdl_factory::create_texture()mi::neuraylib::IMdl_factory::create_light_profile()mi::neuraylib::IMdl_factory::create_bsdf_measurement()mi::neuraylib::IImport_api::import_bsdf_data()ITransaction::copy()from0toLOCAL_SCOPEfor consistency withstore(). The old behavior is still available ifMI_NEURAYLIB_DEPRECATED_ITRANSACTION_COPY_DEFAULT_PRIVACY_LEVEL_ZEROis defined.IMdl_factory::create_texture()to support VDB files.ITarget_code::get_body_texture_count()byITarget_code::get_texture_is_body_resource(mi::Size)to query the information for the individual resources; same for light profiles and BSDF measurements.IFunction_definition::get_mangled_name()was added. For definitions representing real MDL functions this returns the Itanium ABI inspired mangled name used by backends when MDL code is compiled to target code.IUnit::add_function()was added,IUnit::add_environment()is now deprecated.IUnit::add_function()for function definitions added by 3ds.valueand no longer . This might change expression paths to material compilation.nvidia::core_definitionsdf::thin_film()on the DAG.\u,\U,\x, and\Xescapes more like C++\utakes exactly 4 digits, it’s an error if less are given.\Utakes exactly 8 digits, it’s an error if less are given.\xor\Xwithout a digit is an error.\xor\Xwith an overflow is a warning.\uor\Uare now an error.Fixed Bugs
irender_target.h.state::texture_coordinate(0).zto contain thickness (i.e. diameter), not radius, matching the MDL spec.environment_dome_visualizeis enabled (nvbugs 3815369).df::ward_geisler_moroder_bsdfwith multiscatter.::xmay now distinct fromx.\Uescape codes with 8 digits instead of 6 when exporting MDL.opt_level 0code generation for the PTX backend.df::backscattering_glossy_reflection_bsdf().df::ward_geisler_moroder_bsdf().df::ward_geisler_moroder_bsdfif multiscatter is on.df::thin_filmfilm with thickness 0.0.df::thin_film.Iray 2023.0.1, build 367100.3452
IScheduling_configuration::set_cpu_load_limit()before launching any work.motion_vectors_backgroundoption.Fixed Bugs
BSDF_weightcanvas (nvbugs 4131562).::nvidia::dfand::anno, but such imports were not reported, e.g. inIModule::get_import().IPointerandIConst_pointerviaIFactory::clone()without using the optionDEEP_ASSIGNMENT_OR_CLONE.::limits::MIN_FLOATconstant was generated wrong, causing rounding to zero later.Iray 2023.0.2, build 367100.3997
Fixed Bugs
uvtiletextures referenced in MDL modules.<ERROR>marker in the generated source will remain.anno::native()annotations when inlining a module.limits::DOUBLE_M[IN|AX]).mdl_distillerMDL printer for::texmodule imports when textures are used in material parameter defaults.Iray 2023.0.3, build 367100.4598
Fixed Bugs
_'. (MDL-1197)geometry.displacement" are now created in the displacement context.state::cos(). (MDL-1239)Iray 2023.0.4, build 367100.4957
Fixed Bugs
Iray 2023.0.5 Iray Server-only, build 367100.5319
Iray 2023.0.6, build 367100.5773
hlsl_remap_functions": This allows to remap MDL functions (including state functions) to user implemented Native HLSL implementations.mdl_distillercommand line tool tomdl_distiller_clito more clearly separate it from the distiller plugin of the same nameFixed Bugs
enumtointconversion operator an auto-imports, which caused compilation errors in rare cases.1or structs with only one field.Iray 2023.0.7 Iray Server-only, build 367100.6128
Iray 2023.1.0 beta, build 373000.714
Fixed Bugs
Iray 2023.1.0, build 373000.1077
Fixed Bugs
Daz Studio 4.22.1.41 - *Public Build*
Iray 2023.1.1 internal, build 373000.1089
Fixed Bugs
Iray 2023.1.2, build 373000.1755
Fixed Bugs
Daz Studio 4.22.1.74 - *Public Build*
Iray 2023.1.3, build 373000.2208
Fixed Bugs
Daz Studio 4.22.1.88 - *Public Build*
Iray 2023.1.4, build 373000.3036
Fixed Bugs
Daz Studio 4.22.1.110 - *Public Build*
