Victoria 7
12425262729
  • larsmidnattlarsmidnatt Posts: 4,511
    edited June 2015
    I know its possible to make good mats, so I will wait for PA's to make them. But as a base, she is a wash for me.
    BTW, can't you just take a preset skin material you like and apply those settings while leaving the textures in place? If you ctrl click a material preset there is a dialog that lets you choose to ignore textures. So the other settings in the material come over but you can keep the textures as they are.
    This way that skin won't go to waste if you don't like working your own materials.
    Post edited by larsmidnatt on
  • somathatsomathat Posts: 32
    What would really be awesome is to have a morph converter as long as it was 100 percent accurate........Hey a guy can dream can't he......lol
    You can cover morphs over fine. What do you mean somathat?
    This way that skin won't go to waste if you don't like working your own materials.IF the zones were not so different, it would be a easy. Especial if it was like G2F zones to V6 zones, lol.
    428 x 776 - 16K
    edited June 2015
    If you get something you like for the 7th gen figures, you can easily apply that to a character has the V7 textures.
    But going from G2F to G3F doesn't seem to bad. I just tried applying the preset from G2 to G3. It would require a little bit of manual clean up, to correct some of the zones. but it does give you a good start.
    So far the only skin that the preset did not apply to is the arms. which wouldn't be very time consuming or hard to manual do. You would just use the settings from the torso. You could even copy past from the torso, the just update the textures. Which ever is faster.
    heck I even tried going from G3F down to G2F, and that is where more time would be needed since G2 has more skin zones. But even then the material presets can be used IMO.
    edited June 2015
    True it would take a lot of time going from different generations. But if you get something you like for the 7th gen figures, you can easily apply that to a character has the V7 textures.
    Actually, I just tried applying the preset from G2 to G3. It would require a little bit of manual clean up, to correct some of the zones. but it does give you a good start
    White eyes, and no change to the mouth, lol. Tried exactly that a week ago. Just trying to set up an alternate shader for G3F. I ended up just using the shader apply, and dialing each number in manually.
    Even doing that with gen6 to gen6 figures, I sometimes get white pupils (If not the entire eye), lol.
    You're correct, the arms are completely different zone names.
    edited June 2015
    I updated my post.
    ah after some testing, it's inconsistent. I didn't have any issues with the eyes yet but I see different mat presets are behaving different. so yeah, would require some work.
    edited June 2015
    I was just dealing with similar with a bar stool mat, lol. One letter lower case (leg instead of Leg), and that part will not take the mats, lol
    As for my attempt with the G3F altShader mats. (The hair test was with the original shader)
    1632 x 1200 - 969K
    1858 x 543 - 269K
    edited June 2015
    Thanks. I'll try that. I tend not to like to mess with settings too much
    Thanks. I'll try that. I tend not to like to mess with simple n s things to much
    Seems like the easiest thing will be to find a material preset you like from the same generation..so you still might have to wait a bit. But at least if you ever find one you do like, you will be able to go back update V7 with it. Then you could save it as a new preset for the future :)
    So is it possible to use g2f morphs on g3f larsmidnatt?If so how is it done?-Thanks
  • RAMWolffRAMWolff Posts: 10,369
    they will create content for the new figure over the next couple of years, they space out releases of stuff just like they always have. takes time to make stuff so not everything is ready at once.
    Looks like the store still doesn't mention anything about V7 being HD (or list the HD morphs) while I've seen some shapes sold for G3F that specify they HD.
    It's already been mentioned that there are HD morph dials. I don't know where they are, I haven't looked.
  • DAZ_SpookyDAZ_Spooky Posts: 3,100
    edited June 2015
    It's already been mentioned that there are HD morph dials. I don't know where they are, I haven't looked. There is no special dial for it. V7 is HD and sculpted at SubD level 4. This is wrong see below.
    (Though loading V7 will set the rendertime Sub-D to either 2 or 3, depending on if you load it onto G3F or if you load it clean. It isn't set to 4, due to concerns about overtaxing system resources.)
    Edit. OOps. My mistake. I passed some bad information. There will be an HD pack for V7, there is no HD shipped with V7.
    Sorry about that.
    Post edited by DAZ_Spooky on
  • ToyenToyen Posts: 2,048
    Another one : )
    688 x 1100 - 1M
  • jodycourjodycour Posts: 137
    You need to add "C:\Users\Public\Documents\My DAZ 3D Library" to BOTH "DAZ Studio Formats" and "Poser Formats".
    How do you go about doing this? I'm very computer illiterate!
  • jakkujakku Posts: 91
    Toyen said:
    Another one : )
    Looking good :)
    There is no special dial for it. V7 is HD and sculpted at SubD level 4. (Though loading V7 will set the rendertime Sub-D to either 2 or 3, depending on if you load it onto G3F or if you load it clean. It isn't set to 4, due to concerns about overtaxing system resources.)
    Oh, I thought someone mentioned that there were actual dials that one could turn off the HD aspects of the morph(s)
  • PendraiaPendraia Posts: 3,627
    Edit/preferences
    Click on the content library tab.
    Click on Content Library Manager
    They changed the next bit so I had to work this out...
    Click on the Daz Studio Formats in the tree...this will get the add button to work.
    Then select the folder you want to use.
    Same process for the Poser Formats.
    edited June 2015
    There are some HD dials for the face, Mouth Realism, Brow Compression, Cheeks Dimple Crease, Nose Compression.
    Thanks for this info. This is the kind of stuff that's very useful. Now I need to redo my tests :) I was only use sub-d 3.
    OK, redid some tests. 4 does help a lot. going to do more tinkering.
    edited June 2015
    I need some help guys.
    Here is Lilith HD morph at sub-d 1 and sub-d 3. You can see very easily in the collarbone and shoulders the HD details.(you may notice i did not dial Lilith in, cause she would distract you all ;) )
    With V7, I tried sub-d 1 all the way up to sub-d4. There are no new details.
    Are there particular areas where I can seen HD details with Victoria in her body? I'm not seeing any.
    1439 x 1400 - 126K
    edited June 2015
    OK, redid some tests. 4 does help a lot. going to do more tinkering.turn off the HD aspects of the morph(s), was a way with some figures, to make spot-renders quicker (less face-plant time), when setting up scenes, dealing with clothing poke-threw, or nasty shadows on the face. Using a less system-taxing shader is another way.
    Then when it is all set up, the nasty shadows are gone, and the TOS violating Poke-threw has been fixed, then throw on the Mega-shader and level-2 (or higher) HD details.
    2 or 3? 3 loaded from scratch, 2 when dialed onto G3F manually, because G3F is by default at 2 when loaded? As for taxing a system, I do sometimes exclaim, What dose that PA have for a computer, this is slow as (many words), lol.
    OK , Ive had V7 for a couple of days now and have to say I'm sold:))))-Thank you guys and girls at Daz........well done:)))
    edited June 2015
    Now I know something funny is going on at the store. This was not there yesterday when I was looking for G3F morph sets.
    http://www.daz3d.com/da-hd-elf-ears-for-genesis-3-female-s
    Last week, I thought I had noticed a few more G2F figures a page before V7 (that I promptly put in my wishlist), and just assumed I had just not noticed them before that. My memory must realy be bad, and I must be going blind when looking for stuff, lol
    (EDIT)
    Dials! Real dials, thank you DesignAnvil.
    1015 x 1165 - 1M
    I saw that one not long after I first started looking. But when I first looked under genesis 3/all I saw a lot of things were missing in the store that I'd seen. Not sure what's happening there...
    (EDIT)
    I saw that one not long after I first started looking. But when I first looked under genesis 3/all I saw a lot of things were missing in the store that I'd seen. Not sure what's happening there... Well, I assume there is a database of sorts, that things must be added to for that 'Filter' thing to work. Tho when asked for morph sets, I realy did look, and must have missed it (Both times I sifted threw the unfiltered store page).
    edited June 2015
    It probably wasn't — I've noticed the order of stuff on the main store page (and whether new items actually appear right at the top) can vary depending on whether or not you're logged in, whether you've force-refreshed your browser since logging in, and for all I know the phase of the moon... :-S
    Post edited by SpottedKitty on
  • pearbearpearbear Posts: 227
    edited June 2015
    I did a test too, to see if I got the same results because I wasn't noticing any HD detail in V7's body. I just used a plastic shader here, so no normal maps on the skin. Sub 1 is on the left, Sub 4 on the right.
    At first glance it looks like sub 1 and sub 4 give identical results. If I flip back and forth between the sub 1 and sub 4 face and body renders quickly on my computer, they are only veeeery subtly different, though it looks like that is mostly due to sub 4 being naturally smoother. So the body and face don't appear to have any HD details sculpted in unless you dial up some of the HD face morphs like Crows Feet HD.
    On the teeth though, the difference is immediately noticeable. (check out the molars) I have the Mouth Realism HD morph at 100%, as is the default for V7.
    So then finally I dialed up ALL of the face shape HD morphs to 100% (not all the HD expressions though), and yeah there is a lot of new face detail there at Sub 4. I particularly like the Crows Feet HD.
    The teeth and face morphs look really, really great with HD detail. Whatever the resolution the body was sculpted at, the body doesn't appear to have any sculpted detail beyond sub 1 at the moment (V7 normal maps don't count!) but I'm sure some V7 HD product will be released eventually with HD body morphs.
    1600 x 1000 - 608K
    1600 x 1000 - 814K
    1600 x 1000 - 613K
    1228 x 2000 - 849K
    Post edited by pearbear on
  • SpyroRueSpyroRue Posts: 5,020
    I think the "Mouth Realism" HD morph is set on by default by a mistake... It may cause issues when making morphs if it isn't Off, since its on by default, its grey and not easily spotted, I'm not sure if should send a ticket on it. That is unless when switching to base resolution tells it to completely ignore the shaping it makes to teeth angles and alignments
    G3F straight from the Smart tab, also has the 'Navel' on by default.
    Agreed. A face/belly morph made with these on, will just amplify the effect, and not necessarily with a pleasing result.
    596 x 467 - 21K
    SpyroRue said:
    I think the "Mouth Realism" HD morph is set on by default by a mistake... It may cause issues when making morphs if it isn't Off, since its on by default, its grey and not easily spotted, I'm not sure if should send a ticket on it. That is unless when switching to base resolution tells it to completely ignore the shaping it makes to teeth angles and alignmentsG3F straight from the Smart tab, also has the 'Navel' on by default.
    Seconded...er thirded. I noticed this as well.
    thanks for sharing the results. You can certainly see the difference in the teeth.
