How do I turn off the lights?
Tempo777Tempo777 Posts: 6
I bought a bodysuit and I want to render the reflections the way I want it to be. The problem is there are unwanted light even though every light in the scene is still off.
Apparently the light comes from the camera itself, which has it uses. But I want to turn it off for now to control the reflections with my own lights. I've tried every option I could think of.
Post edited by Tempo777 on
    Select the Camera in the Parameters pane, look for 'Headlamp' and switch it off
  • Tempo777Tempo777 Posts: 6
    edited June 2015
    @Jimmy
    Much thanks, but I wasn't talking about the camera as a separate object, but rather the point of view itself.
    However, I figured I need a closed environment. Turns out it's the sun the iray is rendering. I'm gonna fetch myself an environment suitable for photography. I'll appreciate the help if you can lead me to one.
    edited June 2015
    There are some here : http://www.daz3d.com/imaginary_house
    And some here by maclean which are very good too : http://www.daz3d.com/maclean
    Not to mention the Dream Home here : http://www.daz3d.com/catalogsearch/result/?q=dream+home which is very cheap if you join the Platinum Club
    There are probably lots of free ones too on ShareCG, and there are a few that come with Genesis Starter Essentials like Alchemy Chasm. You should also look at the free interactive lessons which often have very useful items that come with them too
    Post edited by JimmyC_2009 on
  • ScavengerScavenger Posts: 2,677
    in iRay..if you set enviroment to "scene only" it won't project a sun, and just use whatever you have in the scene.
    @Jimmy, this Imaginary House will definitely come in handy. Will check on ShareCG as well. Appreciate your help.
    @Scavenger Now that's more like it. Finally I can take my time with the lights, thank you very much :)
