Edge Fall off ERROR!
garbanzolasvegas
I am trying apply an edge fall off to an object in the shader and get those errors
A little help~
Post edited by garbanzolasvegas on
garbanzolasvegas
A little help~
Are you using a plugin for the edge falloff effect?
I think so
I don't think there is one. The Fresnel effect in the transparency and reflection channels will produce that effect, but only with refraction and only in those channels.
My thought would be to check with the plugin developer to make sure that you have the latest version. If you bought it from DAZ, they are notoriously slow about updating the plugins. You'll get better support directly from the dev. from everything I have read.
