Viewport navigation ?
Hi guys, pretty new to daz3d, I was wondering why when I open it, it always display this kind of viewport, how do I change it ? without this 9:16 frame...
  • crosswindcrosswind Posts: 10,121
    Ctrl + 9 to switch back to Texture Shaded DrawStyle. But it seems that the geometry files of the assets were not found...
  • As for the frame, that shows the area that will render - you can turn it off via the Viewport option menu (the lined button in the top-right corner, or right-click the  tab - Show Aspect frame is the one you want) or you can change the render size preset in Render Settings (Active Viewport will render the whole Viewport, but if that changes proiportion so will your render)
  • crosswind said:
    Ctrl + 9 to switch back to Texture Shaded DrawStyle. But it seems that the geometry files of the assets were not found...No
    Not that, the vieport...with that annoying frame..
    Thanks a lot !
