Daz Studio Iray - Rendering Hardware Benchmarking
14142444647
  • Saxa -- SDSaxa -- SD Posts: 880
    edited October 2023
    RayDAnt said:
    I haven't had much of a chance to evlautate things yet (I decided to start over from scratch on everything software-related this time around, from OS to Daz Studio/Daz installed content libraries.) Plus, I am a firm proponent of keeping your installed DAZ content folders slim (only include content needed for a specific project - Daz Studio/DIM supports multiple runtime folders for a reason.) So have never really needed to deal with most of the user-interaction performance issues people tend to have with Daz. So I can't really speak too well to that, although I haven't yet felt the need to tweak things like the Draw settings (normally I am all over those) to improve usability. So there is that. It's definitely a huge improvement over the DDR4-3000 I was coming from, but suspect any major improvments are more to do with the new overall architecture of the chipset rather than RAM speed (fwiw the mt/s - mega transfers per second - distinction is entirely about sounding smart...)
    The tight content management system you're using sounds very efficient.  Am not there yet as still setting things up.  I do manually disable morphs though that am no longer using, and that has helped alot.  When done setup will do same as you.
    When i was saying interactivity, was thinking more along the lines of many characters, with wearable, and environments.  That sitting in RAM (disabled ALL my windows harddrive caching), am curious how differnt RAM/CPU combos would affect that.
    Am really looking forward to upgrading when 5*** series shows up with way better system-RAM then too.  But won't have near same number of GPUS as you.
    Could i bug you though to elaborate about chipset design maybe being more key?  CPUs, unlike, GPUS, seem pretty slow relatively speaking to GPUs to improve speeds. Plus lots of software functions, like animations, are still  by and large single core, whcih means cpu top speed is most important. How would chipset architecture be an additional component to that top speed and RAM access?  My RAM speeed is currently 3600mhz (not smart sounding lol).
    It'd be even faster if  I had waited an additional year to upgrade - or ten (this particular machine has been in a constant state of gradual upgrade since 2007.) That's just the way these things work.
    I really should do a full write-up on this PC some time (Tower 900 builds are rare enough as it is, and I don't think I've seen a single other attempt at turning one into a performance-focused workstation - despite how capable they are of that.) Yes, it's a bulky, expense platform. But if you're living in the realm of real upgradable workstation chassis already, that's kind of all a moot point anyway, so...
     As you probably remember have a tower 900 too. Love the room, except for the power supply location.  Nightmare that one.  Would def be intrigued by a perf-based workstation writeup.  Hope you do!  Heck, i'm still air cooled on mine.  One good reason stilll only 1 gpu.  Airspace would be tight with 2+.  Main GPU temp that MSI afterburner monitors never exceeds 68degC reagrdless what i throw at it, but the hot junction/hot spot, yeah one day looked and based on hwinfo64 that was around 88-90 degC.  Not sure if liquid cooling can deal with that one?
    Post edited by Saxa -- SD on
  • oddboboddbob Posts: 444
    My 4090 with +100 core +1000 vram and an 80% power target tends to run around 48c core, 50c vram & 56c hotspot with a fairly simple loop while using DS in a room with an ambient temp in the low 20s.
    The only fans apart from the psu are the 5 attached to rads. The fans are typically between 400 - 1100 rpm depending on water temp, hitting about 1100 during an hour long render.
    An hour of cyberpunk with everything up to 11 hits about 60/50s/72 with the fans at about 1250.
    edited October 2023
    Hmmm. Cyberpunk dialed to max only yields you 72?  Only have a 3090 though it is an Xtreme variant, and that would have that hotpsot at 88-90, though I can't obvi goes as high as you can.
    Has water cooling really improved? Seems when I looked not too long ago the performance diff anecdotally was not quite as pronounced.
    Thought i was doing well with 68degC (what most users report, or have been) vs that hotspot which is lot hotter.
    So what are you getting for reg reported GPU temp?  ie vs my 68degC (not junction nor hotspot ie. my 88-90).
    Curious if your difference is less than mine. In that case rad cooling into GPU would be worthwhile for sure if want to keep for years and years.
    lol, the way am updating GPUs, i update before they ever get heat stressed.  But still. Like lower temps, esp. if lots lower.  Then the whole risk of water cooler leak is more worthwhile, and doing reg maintenance.
    You can't really directly compare 3090 and 4090 numbers because the 4090 is easier to cool because of the board layout but can draw more power. I had a watercooled 3090 FE and under a heavy gaming load I used to get high 50s on the core and high 70s on the ram with the hotspot somewhere between the two. Knock about 6c off if rendering in DS. Truthfully, if the 3090 temps bother you I'd sell it and get a 4090 rather than go to the expense of building a loop. You'd need a couple of decent sized rads, pump and reservoir, fittings , tube and other assorted parts. All that plus what you could sell a 3090 for gets you into 4090 territory.
  • prixatprixat Posts: 1,616
    RayDAnt said:
    prixat said:
    BTW the benchmark scene will not queue to the Iray server! It has no problem streaming to the preview or a render window.
    It's a vague 'integer out of range error' and the transfer to the server aborts immediately.
    (The server uses Iray 2023.0.2 (367100.3997) and generally gives the error 'deprecated canvas parameters identified' but that does not stop the queuing)
    So far only the benchmark scene has failed to queue.
    What happens if you re-save the benchmarking scene (without modifying any of its content) and then try queing
    that to the render server?
    Just tried re-saving the benchmark scene via the latest Beta, still "job rejected by the server".
    edited November 2023
    Didn't know that about 4090 being easier to cool. Good to know!  Have not looked at 4*** series, as had decided will wait for 5***series after having read some "hopium en mass" about what they may include, especially more VRAM.
    Not worried about these temps, being under 90degC.  For me again interesting part was the different board design. Thanks for saying! Guilty of not looking. Usually do. But as say, had decided to upgrade with 5*** series. Maybe in <1 year now? Look at water cooling then too.  Rather spend time on DAZ content than PC building.
    An upgrade to the server was available this week
    Upgraded server to 2023.0.5 (build 367100.4957) however the benchmark scene was still rejected, with the same 'Integer out of range' error, when trying to queue it. ...but does works when streaming!
  • RayDAntRayDAnt Posts: 1,156
    Unfortuantely I don't have access to an Iray Server instance to test againts at the moment. Have you filed a bug report with Daz about it? If not, I highly suggest doing so here.
    Post edited by RayDAnt on
    I have some render servers, I can stand you up a test server if you want to do some testing.
  • System Configuration
    System/Motherboard: SuperMicro X12
    CPU: 2x Xeon Gold 6348
    GPU: 4x RTX6000 ADA Generation
    System Memory: 512 GB DDR4 ECC @ 3200 MHz
    OS Drive: SK hynix Platinum P41 2TB PCIe NVMe Gen4
    Asset Drive: 256 GB RAM DRIVE
    Daz Studio: 4.22.0.1 Public Build
    Operating System: Win 11 Pro
    Nvidia Driver: 537.70
    Benchmark Results
    2023-11-14 20:48:50.056 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Device statistics:
    2023-11-14 20:48:50.056 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (NVIDIA RTX 6000 Ada Generation): 408 iterations, 1.245s init, 18.159s render
    2023-11-14 20:48:50.057 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 1 (NVIDIA RTX 6000 Ada Generation): 469 iterations, 1.270s init, 18.519s render
    2023-11-14 20:48:50.057 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 2 (NVIDIA RTX 6000 Ada Generation): 462 iterations, 1.359s init, 18.431s render
    2023-11-14 20:48:50.057 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 3 (NVIDIA RTX 6000 Ada Generation): 461 iterations, 1.345s init, 18.475s render
    2023-11-14 20:48:50.391 [INFO] :: Finished Rendering
    2023-11-14 20:48:50.457 [INFO] :: Total Rendering Time: 22.97 seconds
    Iteration Rate: 97.20 iterations per second
    Loading Time: 4.451 seconds
    Current public build and updated drivers.
  • TheKDTheKD Posts: 2,711
    System/Motherboard: ASUS TUF GAMING X570-PLUS
    CPU: AMD Ryzen 9 3900X
    GPU: MSI RTX 4090 Gaming X Trio
    System Memory: corsaire 16gb x 4 64gb total
    OS Drive: samsung 960 EVO
    Asset Drive:
    Power Supply: EVGA SuperNOVA 1300W
    Operating System: Windows 11, Build 22621, Enterprise
    Nvidia Drivers Version: 531.79
    Daz Studio Version: 4.21.1.108
    Optix Prime Acceleration: No
    Benchmark Results
    DAZ_STATS Total Rendering Time: 1 minutes 12.91 seconds
    IRAY_STATS 1.0   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 4090): 1800 iterations, 1.792s init, 69.006s render
    Iteration Rate: 26.0846
    Loading Time: 3.904 seconds
  • edited November 2023
    System/Motherboard: ASUS Pro WS WRX80E-SAGE-SE WiFi
    CPU: AMD Ryzen Threadripper Pro 5975WX
    GPU: (3x)PNY GeForce RTX 4090 XLR8
    System Memory: (8x) Samsung 3200 MHZ Registered RDIMM M393AG40AB2-CWE (512 MB)
    OS Drive: SAMSUNG SSD 990 Pro M.2 4TB
    Asset Drive: WD_Black SN850X 2TB
    Power Supply: Seasonic Prime ATX 3.0 1600 watt
    Operating System: Windows 11 Pro Build 22621
    Nvidia Drivers Version: 31.0.15.4601 Studio
    Daz Studio Version: 4.22
    Benchmark Results
    2023-11-17 16:06:15.414 [INFO] :: Finished Rendering 2023-11-17 16:06:15.444 [INFO] :: Total Rendering Time: 25.81 seconds
    IRAY_STATS
    Iteration Rate: CUDA device 2 (NVIDIA GeForce RTX 4090): 600 iterations, 0.694s init, 21.930s render: CUDA device 1 (NVIDIA GeForce RTX 4090): 579 iterations, 0.701s init, 22.875s render: CUDA device 0 (NVIDIA GeForce RTX 4090): 621 iterations, 0.719s init, 22.714s render
    Loading Time: 2.935 seconds
    900 x 900 - 1M
    Post edited by ThatJacobGuy_fde6c304cf on
    Benchmark Results
    IRAY_STATS
    Thanks, would you mind doing the bench with one 4090? I don't think we have a 4.22 test with one 4090. I think the speed is pretty much the same, but it would be nice to verify.
    here are the results for one:
    CPU: AMD Ryzen Threadripper Pro 5975WX111111111
    Benchmark Results
    2023-11-18 04:58:07.144 [INFO] :: Total Rendering Time: 1 minutes 4.23 seconds
    IRAY_STATS
    2023-11-18 04:59:12.446 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 4090): 1800 iterations, 0.503s init, 62.449s render
    Loading time: 1.781 seconds
    Benchmark Results
    IRAY_STATS
    Thank you for taking the time to do that. That comes to 28.8 iterations per second, which is spot on with where the 4090 has been.
    BTW, Iray 2023.0.6 is now in the Daz PRIVATE Beta branch. This surprised me a bit, because for one, this is the latest version that just dropped on November 7. So Daz just skipped all the others, lol.
    Hopefully we will get Iray 2023 released to the public beta soon. This is a big update, with lots of promised performance improvements. Not only do they claim Iray 2023 runs better on RTX 4000, but they say it improves speeds for ALL hardware because of other fixes they have done. They optimized how Iray calculates certain geometry, for example, so in some scenes we may see improvements not observed in other scenes. They also revamped the caustic sampler and guided sampler, making them faster. They also claim many bug fixes, and who knows, these fixes might be fixes for some problems we have had with Iray 2022.
    Of course, that is what they claim to have done. We cannot be certain until we get our hands on it. Considering it is only in the private beta, it may be a couple months before it goes public.
  • nonesuch00nonesuch00 Posts: 18,757
    edited January 2024
    Since I need to test that my new GeForce RTX 4070 is properly working before the rest of my new PC parts come in, I decided to do this DAZ Studio iRay benchmark again.
    System/Motherboard: Gigabyte B450M DS3H WIFI (AMI UEFI BIOS F66B)
    CPU: AMD Ryzen 7 5700G with Radeon Graphics / 3.80 GHz
    GPU: PNY GeForce RTX 4070 GPU 12GB XLR8 Gaming VERTO EPIC-X RGB / 1920MHz
    System Memory: 2x16GB Patriot Premium / 3200MHz
    OS Drive: PNY CS2130 2 TB M.2-2280 PCIe 3.0 X4 NVME SSD
    Asset Drive: Crucial 2 TB Sata III SSD
    Power Supply: SeaSonic 750W Gold
    Operating System: Windows 11 Pro 23H2 22631.2715
    Nvidia Drivers Version: 546.01 Studio
    Daz Studio Version: DAZ Studio Pro Public Beta 4.22.0.7 64-bit
    Optix Prime Acceleration: N/A
    Benchmark Results
    DAZ_STATS:  2023-12-03 15:20:22.737 [INFO] :: Total Rendering Time: 2 minutes 21.87 seconds
    IRAY_STATS: 2023-12-03 15:20:22.202 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 01800 iterations after 139.706 s.
    Iteration Rate: 1800 iterations/139.706 seconds = 12.88+ iterations/second
    Loading Time: 261.87 seconds TRT - 139.706 seconds rendering time = 122.164 seconds loading time
    Post edited by nonesuch00 on
  • jeremie.dev said:
    Benchmark Results
    2023-10-05 01:31:17.057 [INFO] :: Total Rendering Time: 31.64 seconds
    2023-10-05 01:31:21.710 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info: CUDA device 0 (NVIDIA GeForce RTX 4090): 566 iterations, 1.552s init, 27.862s render
    2023-10-05 01:31:21.710 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info: CUDA device 1 (NVIDIA GeForce RTX 4090): 619 iterations, 1.519s init, 27.908s render
    2023-10-05 01:31:21.710 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info: CUDA device 2 (NVIDIA GeForce RTX 4090): 615 iterations, 1.636s init, 27.745s render
    Iteration Rate:
    GPU 0: 20.31 iterations per second (Fewer iterations, but the same card. Possibly due to my monitors? I use 2x4K monitors.)
    GPU 1: 22.18 iterations per second
    GPU 2: 22.17 iterations per second
    Loading Time: 3.732 seconds
    I don't know if this was supposed to be obvious but I can confirm it. Even using only 1 monitor at fullhd resolution, running my RTX 4090 as the display card my bechmark results were always 25.6~ iterations per second in DAZ 4.22 BETA, no matter what I did I could not get it to 28 IPS. (I kept the card itself at stock speeds, I just mean other stuff like closing all background process, unplugging the internet, removing other gpu, unplugging slow storage devices... I know these aren't supposed to affect the rendering once it's loaded in the GPU but was worth a try I guess).
    RTX 4090 ASUS ROG STRIX @ stock speeds
    Now I did the bench again with another card as the display card, selected only the RTX 4090 and got the 28.3~ IPS in DAZ 4.22 BETA. Will go over the thread later to check other results.
    I know the benchmark isn't absolute, but considering a RTX 3060 can do the avarage of 6.6 IPS, isn't 3 iterations too much of a loss only by using the card as the display for 1 monitor?
    charliecharles said:
    jeremie.dev said:
    Benchmark Results
    Iteration Rate:
    Imo people tend to hugely overlook how much of a processing load driving windows graphics is on a GPU. Here's a fun little demosntration you can do: Pop open Task Manager to the tab showing the 3D Activity graph for the GPU you are using to drive your display(s). Then start moving a window (not the Task Mnaager window) as rapidly as you can all around your screen(s), and watch as the activity graph starts to go up. Now consider the fact that that is just the processing it takes for a single window. Every window, every status box, every system overlay is an additional piece of stuff that the GPU is having to contend with while you do whatever else it is you think you are actually using the GPU to do. The WDDM (Windows Display Driver Model) is essentially like having a game running constantly in the background whenever it's being used to drive displays. An extremely well optimized one (especially at idle), but one whose overall load on system resources is still there regardless.
    Remember this test is not an absolute. The results could also be influenced by how short the test is now. A delay of just a few seconds can translate to multiple iterations being lost. Thus the penalty gets higher for the fastest GPUs. A better way is to test on some larger scenes and observe how much impact it has.
    That said, it is also possible the issue comes Iray 2022, which is still what Daz uses. The 4090 can achieve 28+ iterations with Iray 2021. At some point, one day, who knows when, Daz Studio may get Iray 2023. Iray 2023 showed up in the PRIVATE beta channel recently. So hopefully it will make its way to the public beta eventually. It did not make it into the beta that just dropped which contains Face Transfer 2. You just have to keep asking Daz when we might finally get to play with this new Iray.
  • Been a while, i've assembled a new computer to replace my 3-year-old Alienware m17 R4 laptop.
    System/Motherboard: MSI B550 Tomahawk Max WIFI
    CPU: AMD Ryzen 7 5700X @ stock (Power Limited to 65W)
    GPU: MSI Ventus 2X OC RTX 4060Ti 16GB @ stock  (Power Limited to 100W)
    System Memory: Kingston Fury BEAST @ 3200 MT/s
    OS Drive: Kingston NV2 Gen4 NVME 2TB
    Asset Drive: Same
    Power Supply: MSI A850GF 850W 80+ Gold PSU
    Operating System: Windows 10 Home 22H2
    Nvidia Drivers Version: 546.33
    Daz Studio Version: 4.22.01
    Optix Prime Acceleration: Enabled
    Benchmark Results
    2023-12-16 08:19:56.185 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 4060 Ti): Scene processed in 0.979s
    2023-12-16 08:19:56.186 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 4060 Ti): Allocated 15.450 MiB for frame buffer
    2023-12-16 08:19:56.191 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 4060 Ti): Allocated 1.969 GiB of work space (2048k active samples in 0.005s)
    2023-12-16 08:19:56.191 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 4060 Ti): Optimizing for cooperative usage (performance could be sacrificed)
    2023-12-16 08:19:56.443 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend info : Allocating 1-layer frame buffer
    2023-12-16 08:23:36.013 [INFO] :: Finished Rendering
    DAZ_STATS
    2023-12-16 08:23:36.035 [INFO] :: Total Rendering Time: 3 minutes 50.21 seconds
    IRAY_STATS
    Iteration Rate: (1800 / 220.322s) 8.1698 iterations per second
    Loading Time: ((230.21) - 220.322)  9.8888 seconds
  • What version of iray does Daz Studio 4.16.0.3 use? (I can only find info for 4.16.0.003 which says iray 2020.1.6, but I'm not sure if that extra zero is a typo). I'm looking into buying a new GPU but I don't want to upgrade studio any further and I want to make sure I get a GPU compatible with what I currently have installed.
    It certainly looks like a typo, and if the version of interest doesn't specify a version it will be using the one that was last abbounced.
    edited December 2023
    Iray 2020.1.6
    The "extra" zeros seen eg. here are on purpose for formatting reasons (they make scanning up and down through version lists at a glance easier to do.)
    System/Motherboard: Supermicro X12
    OS Drive: SK Hynix Platinum P41 2TB PCIe Gen4
    PSU: 2x Corsair AX1600i
    Nvidia Driver: 537.99
    Daz Studio: 4.22.0.15
    Benchmark Results with 4x RTX6000 ADA
    2023-12-27 13:26:09.696 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Device statistics:
    2023-12-27 13:26:09.696 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (NVIDIA RTX 6000 Ada Generation): 414 iterations, 1.220s init, 17.262s render
    2023-12-27 13:26:09.696 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 1 (NVIDIA RTX 6000 Ada Generation): 461 iterations, 1.130s init, 17.041s render
    2023-12-27 13:26:09.696 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 2 (NVIDIA RTX 6000 Ada Generation): 451 iterations, 1.172s init, 17.015s render
    2023-12-27 13:26:09.696 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 3 (NVIDIA RTX 6000 Ada Generation): 474 iterations, 1.147s init, 17.752s render
    2023-12-27 13:26:10.519 [INFO] :: Finished Rendering
    2023-12-27 13:26:10.585 [INFO] :: Total Rendering Time: 22.45 seconds
    Iteration Rate: 101.4 iterations per second
    Loading Time: 4.698 seconds
    Benchmark Results with 1x RTX6000 ADA
    2023-12-27 23:27:59.624 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Device statistics:
    2023-12-27 23:27:59.624 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 3 (NVIDIA RTX 6000 Ada Generation): 1800 iterations, 1.157s init, 63.457s render
    2023-12-27 23:28:00.293 [INFO] :: Finished Rendering
    2023-12-27 23:28:00.360 [INFO] :: Total Rendering Time: 1 minutes 7.15 seconds
    Iteration Rate: 28.3657
    Loading Time: 3.603
    Daz 4.22.0.15 appears to be faster. Following the conversation, I tried a few runs with just a single 'non-display' GPU. The results are similar to a 4090. When I tested 3x GPUs, skipping the one being used for display, it was just under 80 iterations per second; (79.87 / 3 = 26.62 average). I think if something else was pushing the display(s), I would land right around 105 iterations per second.
  • skyeshotsskyeshots Posts: 151
    Anyone have luck running the benchmark on the Beta 4.22.1.41 with new IRAY version?
    Having issues? It's working for me, but I had to go and manually download/update my graphics drivers for it to work (Iray 2023.1.0 requires driver version 545.84 as mininum, and GeForce Experience doesn't seem to be pushing out the latest Studio driver release past that version for some unknown reason. Maybe server update issues.)
    edited January 2024
    Asset Drive: Crucial 2TB SATA III SSD
    Benchmark Results
    Since it was asked if anyone had run the benchmark with the public beta 4.22.1.41 I have run it here.
    Hardware Notice:
    a) New MSI motherboad replacing the Gigabyte motherboard
    b) New Fikwot 2TB USB M.2 NVMe SSD replacing the 2TB  Crucial Sata III SSD
    Software Config Notice:
    a) 1st quoted test was ran without CPU fallback while the below test was ran with CPU fallback and that seems to have allowed DAZ Studio to shell off part of the rending to the CPU. At least that's what I think has happened. That might explain the longer render time. Correct me if I'm wrong and you know why.
    b) The nVidia driver and Windows 11 were also both updated. I am using the stable "Studio" driver.
    System/Motherboard: MSI MAG Tomahawk B550M WIFI
    Asset Drive: Fikwot FN501 Pro 2TB NVMe SSD
    Operating System: Windows 11 Pro 23H2 22631.2861
    Nvidia Drivers Version: 546.33 Studio
    Daz Studio Version: DAZ Studio Pro Public Beta 4.22.1.41 64-bit
    Benchmark Results
    DAZ_STATS:  2023-12-03 15:20:22.737 [INFO] :: Total Rendering Time: 2 minutes 31.79 seconds
    IRAY_STATS: 2023-12-03 15:20:22.202 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 01800 iterations after 148.816 s.
    Iteration Rate: 1800 iterations/148.816 seconds = 12.095+ iterations/second
    Loading Time: 151.79 seconds TRT - 148.816 seconds rendering time = 2.974 seconds loading time
    Hardware Notice:
    Re: CPU fallback, you should see the CPU listed in the render log output.
    System/Motherboard: MSI MPG Z490 Carbon EK X
    CPU: I9-10850K @ 3.6 ghz
    GPU: RTX 4000 ADA (20 GB - Single Slot GPU)
    System Memory: 64 GB Corsair Dominator Platinum DDR4-3466
    OS Drive: Samsung 970 EVO SSD 1TB – M.2 NVMe
    Asset Drive: Same
    Daz Studio Version: 4.22.1.54 (Public Build)
    2024-01-12 23:02:11.312 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Device statistics:
    2024-01-12 23:02:11.312 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (NVIDIA RTX 4000 Ada Generation): 1646 iterations, 3.135s init, 168.622s render
    2024-01-12 23:02:11.312 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CPU:                                            154 iterations, 1.830s init, 168.312s render
    2024-01-12 23:02:11.851 [INFO] :: Finished Rendering
    2024-01-12 23:02:11.942 [INFO] :: Total Rendering Time: 2 minutes 59.41 seconds
    Loading Time: 10.788 seconds
    GPU Iteration Rate: 9.76 iterations per second
  • V8 InfiniteV8 Infinite Posts: 31
    edited January 2024
    System/Mothboard : Gigabyte Z790 Gaming X AX
    CPU : I9 13900K (no overclock)
    GPU : RTX 4070 SUPER 12 Go Gigaoctet Windforce oc
    System Memory : 32 Go DDR5 Kingston Fury X
    OS Drive : Samsung 990 PRO 2TO -nvme
    OS : W11
    Nvidia Driver : 546,45
    Daz Studio 4.22 (Last Public Build...)
    Dont know render infos, but she render at 1800 itérations in 2 minutes, 10 secondes. GPU Only
    GPU + CPU : 1800 ité at 1 minute 57 sec rougir
    /Google Traduction
    Post edited by V8 Infinite on
