Removing Iray Shaders?
Nyghtfall3D
How does one remove Iray shaders?
Nyghtfall3D
Just reapply the DS textures or apply the DS default Shader or any other shader built for 3Delight.
I applied Iray shaders to a set of sphere primitives. I want to remove the Iray shaders so I can run the scene through Reality to compare default shader quality.
Just apply the DS default shader it can be found in shaders or shader presets not sure which sorry can't look right now, under DS shaders.
Found it, thanks.
