Removing Iray Shaders?
Nyghtfall3DNyghtfall3D Posts: 815
How does one remove Iray shaders?
  • scorpioscorpio Posts: 8,533
    Just reapply the DS textures or apply the DS default Shader or any other shader built for 3Delight.
  • Nyghtfall3DNyghtfall3D Posts: 815
    I applied Iray shaders to a set of sphere primitives. I want to remove the Iray shaders so I can run the scene through Reality to compare default shader quality.
    Just apply the DS default shader it can be found in shaders or shader presets not sure which sorry can't look right now, under DS shaders.
    Found it, thanks.
