Creating a smoothing modifier in DS 4.8.0.55
TimbalesTimbales Posts: 2,458
I'm trying to create a smoothing modifier on a prop that I have parented to M6, but the menu settings have changed. It no longer under Edit/Figure(or Object). Can anyone point me in the right direction?
  • IceCrMnIceCrMn Posts: 2,334
    I use that version of 4.8 and mine still shows the smoothing modifier under Edit>Figure/Object>Geometry>Apply Smoothing Modifier. Maybe something has gotten messed up in your UI.You could try switching UI styles and see if that gets it sorted out.
  • TimbalesTimbales Posts: 2,458
    that did it, thanks!
    It had switched over to City Limits Lite
