Creating a smoothing modifier in DS 4.8.0.55
Timbales
I'm trying to create a smoothing modifier on a prop that I have parented to M6, but the menu settings have changed. It no longer under Edit/Figure(or Object). Can anyone point me in the right direction?
I use that version of 4.8 and mine still shows the smoothing modifier under Edit>Figure/Object>Geometry>Apply Smoothing Modifier. Maybe something has gotten messed up in your UI.You could try switching UI styles and see if that gets it sorted out.
that did it, thanks!
It had switched over to City Limits Lite
