My Fenrir wolf doesn't look furry. {RESOLVED - THOUGH DON'T KNOW HOW}
WillowRavenWillowRaven Posts: 3,787
edited June 2015 in The Commons
There's a displaced option, but it doesn't look very displaced, lol.
Any suggestions or am I missing something?
Working in DS4.7
Post edited by WillowRaven on
    The critter just doesn't seem to be very furry; there are tufts of bristles behind the legs, on the chin and shoulders, a bottle-brush tail and a couple other places, but most of his skin is smooth. And it's a displacement effect, so there's nothing to see until after rendering. I wonder if I can use LaMH to get a better fur effect.
  • WillowRavenWillowRaven Posts: 3,787
    Even after render, it looks smooth to me. But I would LOVE a LAMH preset. I'm going for a 'black dog' effect. Wolf-ish, mythical, etc.
  • ValandarValandar Posts: 1,418
    If you're using Iray, I don't have shaders for it ready yet. Effectively, Iray doesn't do sub-polygon displacement, meaning that the "tufts" just swell a bit, rather than look like dirty, spiky fur tufts.
    If they're there and it's not enough, I must apologize. The intent was a monstrous, diseased wolf monster, actually.
  • Richard HaseltineRichard Haseltine Posts: 111,278
    Iray will do fine displacement, by use of the SubD level on the mesh and then on the Iray uber shader, but it's expensive in terms of memory use.
    I haven't made the switch to Iray just yet. It took me three years to go from DS3 to 4, lol.
    But some LAMH would be absolutely spectacular :D
    A couple of things when it comes to displacement...shading rate matters a lot. For very fine displacement (hair/fur) it MUST be at 0.1 or LOWER. The 'fineness'/resolution of the displacement map is important, but the super-fine shading rate is probably just as important.
    And while the direction the buckets travel (horizontal, vertical, zig-zag, etc) usually doesn't matter, when it comes to fine/large distance displacement of something that is supposed to be 'strands' (hair/fur/grass) then you need to have the buckets moving in a direction parallel to the main axis of displacement...so if you've got hair sticking up, use a vertical order. This will prevent 'clipping' at the bucket edges.
    Also, doing these things will increase render times...especially if you are using a shader that has 'trace displacements' option (and you turn it on).
    Oh, yeah...fur/grass needs some pretty large max numbers...the min can be 0, but max should be at least 1 (that makes it a full cm) and up to 3 or 4 (longer than that and you really end up with too much clipping). Adjusting the bucket size UP will help eliminate some clipping with large max values.
  • KaribouKaribou Posts: 1,325
    If you have the full LAMH, you can make your own. Alessandro exported the hair on his arctic fox as an obj and rendered it in Iray. http://www.daz3d.com/forums/viewreply/813885/ Discussion on how it was done follows a few posts later.
    I don't have the full LAMH product. Just the freebie for presets.
    I am liking some of those Iray renders.
    edited June 2015
    Just in case anyone is curious, when I rendered at 5000 pixels, the displacement showed up. I don't know why it didn't at 700.
    Here is the final work:
    2000 x 1385 - 268K
    1250 x 2000 - 255K
