Carrara Challenge XVII - Wonder of my World - WiPs Thread
1234568»
  • StezzaStezza Posts: 8,979
    I put some water repellent spray on me ugg boots the other day... could use that if I can find it!
  • HeadwaxHeadwax Posts: 10,513
    Aussie birds are tough - at least the ones I have been out with :)
    finally finished
    2000 x 1500 - 877K
    2000 x 1478 - 3M
  • JonstarkJonstark Posts: 2,738
    It's a good thing I started early on this challenge, because this month has been a killer for me and I've gotten almost nothing done.
    I don't think I had done screenshots of my lighting setup, which is really dead simple as almost all lighting is coming from a square plane just outside the door to give the illusion of a 'hallway light' spilling into the room. Using full global illumination, the glow channel of the square (which is set very high) sheds light through the doorway into the room. There's also a very mild glow on the lampshade.
    I made the walls on the near side of the room invisible so that my lighting setup was more evident (last pic).
    1299 x 506 - 147K
    1298 x 503 - 100K
    1305 x 506 - 332K
    By my reckoning ( it's nearly 3pm on the 24th where I am ) which makes just over an hour to go in DAZ Time to get your entries in..
    chances are good in getting prizes in this challenge... :-)
    but picking will be difficult ..
    Voting thread is up and running
    http://www.daz3d.com/forums/discussion/56009/
    Thanks for those of you who have done such great WiPs.. now the time has come to vote for you favourites ;-)
    yippee :) Nice work Stezza! Oh I my ppm is now working proplee
    Only a few days left to get your votes in ... if you haven't already
    anyone can vote so get on over to the voting thread and do the deed ;-)
    I'm still deciding! Top notch entries!
    Drain it all out to the very end..
    Only one hour to go till voting finishes...
    Please vote if you haven't done already... ;-)
