Show Us Your Iray Renders. Part III
1…1415171920…50
  • MEC4DMEC4D Posts: 5,249
    I agree , if you have the values for everything under hand ;)
    MEC4D said:
    custom or measured curve is not physical correct ..
    Good to know. Wasn't keen to either have to calculate or looking up for the values.
    Digged trough dozends of websites to get to my tiny collection of IOR values.
    Custom curve and measured "can" be physically correct, but they don't have to be. Custom curve with 0.04 normal, 1.0 grazing and 5.0 exponent is correct for most plastics for instance. Custom curve is part of how the PBR modes in the uber are implemented.
    Thanks Stefan , I was looking for that one
    Just to let you know that there is a new beta build available: 4.8.0.53.
  • Joe.CotterJoe.Cotter Posts: 3,362
    MEC4D said:
    I did not said just , I give example with metal, the same go for water, glass and other stuff
    and I mean Fresnel(ior) not typical index of refraction IOR, as I was talking about reflection
    Gedd said:
    Just for metals?
    Ok, just wanted to clarify. From what I've been seeing in my research, Fresnel is one of the best kept secrets of PBR it seems. Everything has Fresnel, just getting the ior/curve correct for the material seems to be key.
  • abe01abe01 Posts: 29
    edited May 2015
    Fusion 1.800.000 polys - rendered on my Note - GT540M 1GB GPU only - in 8 minutes each
    1366 x 768 - 931K
    1366 x 768 - 908K
    Post edited by abe01 on
    For me it is easy cake, use 1.33 for water 1.52 for plastic or 1.63 for high reflective plastic 12 for less reflective metals and 80+ to 100 for mirrors , the IOR value inder top coat is limited so you have the set it off first under parameters .
    I am tired of looking for glossy and other values and just use simple Fresnel and everything looks good I guess
    I have all curves for metals and others but there is missing other segment under so it will be not possible to get it 100 but good enough to wow the audience
    I can create metals based on glossy specular for ok look but it will looks better with Fresnel so YES !
    that why my next shader product is all based exclusive on Fresnel values as cool things can be make with
    Gedd said:
    Just for metals?
    edited May 2015
    Nothing special. Genesis+MS Lycan. Tried a suggestion by Hellboy to use the wax shader on the hair. Saved out a basic, mapless starting point for Iray skin and tweaked from there (G2F + script to rename surface zones and saved it out to use on previous gen chars). Also tweaked the Lycan's head z-scale to elongate it a bit and moved the upper/lower jaw nodes to compensate.
    I have no idea how to handle dark, peachfuzz style skin, but I think I have a good start on the hair/eyes/mouth.
    This will be a constant work in progress as I have an idea for it that I'll eventually render out bigger.
    800 x 640 - 500K
    Post edited by Lissa_xyz on
    In your case the best would be to use the Car paint and change the colors , base dark then glossy etc and reduce the size of the metal flakes .. it will give you more fur like look
  • barbultbarbult Posts: 27,608
    Wow! Looks special to me!
    Car paint for fur? Never would of thought of trying that. Thanks!
    Thank you!
  • pearbearpearbear Posts: 227
    The werewolf looks great. Wax shader for the hair sounds interesting, I'll have to try it. I'm thinking that might look really nice when backlit. I was just working on something peach fuzz-related myself. I was dissatisfied with how the hair rendered here and decided to paint over it in Photoshop, and then thought while I was at it I should paint a hint of peach fuzz on the characters' bellies and arms, since it's usually visible on unshaven areas of a woman's body in edge lighting. (I once saw someone on Deviant art doing this on their renders and thought it was cool) Also a bit of fuzz from stray fibers at the edge of the clothing.
    The initial reason for the render was to test out some joint bending morph corrections to the custom body morph I've been working on, particularly elbows and shoulders. I think the elbows are working pretty good but I haven't yet managed to get the shoulders the way I want when the arms are way over the head. When 90 degrees out they're getting better though.
    1200 x 1800 - 2M
    Fresnel is easy to explain
    the light goes to a microholes of a surface and will be bend in various degrees. the IOR of the surface split the ligth in different colors(prism effect).
    the same effect is to see on the data side of a CD-ROM, DVD. The holes burned from the laser do the fresnel effect and the IOR of the material makes the rainbow colors.
  • DzFireDzFire Posts: 1,473
    Drop Through. Lit entirely with mesh based lights
    1850 x 1000 - 1M
    edited May 2015
    IOR
    on the left is a material with single IOR like glass or diamond
    on the right is a material with double IOR like calcite mineral
    sorry about the blurrish Double IOR material, its WIP
    768 x 512 - 709K
  • LyonessLyoness Posts: 1,641
    OOOOOOOH.
    awesomely beautiful.
    nicely done.
    edited May 2015
    IOR and Abbe number
    the prisms have the folling IOR and abbe numbers
    from left to right
    IOR1.4 - Abbe 3
    IOR1.4 - Abbe 10
    IOR1.8 - Abbe 3
    IOR1.8 - Abbe 10
    447 x 254 - 17K
    1366 x 768 - 1M
    i like it
    nasenbaer said:
    Fresnel is easy to explain...
    It's not understanding the basic concept, it's getting a proper Fresnel ior curve for a given material.
    this depends on a lot of factors like wavelength of the light, distance between molecules or atoms, spaces and so on to create the bending of the light. In the case of the CD, the IOR of the clear plastic - depending of the angle/degree of the view creates the colors - Dispersion like a prism.
    edited May 2015
    Don't think I'm quite getting this car paint fur trick. lol
    Closed his eyes/mouth so it renders faster until I manage to get something I like. Maybe it's just me.
    I may try making a displacement or normal map for very small hairs and see if that helps.
    800 x 640 - 458K
    edited May 2015
    No, if the Fresnel response curve is correct for a given material, it will act correctly for that material under various lighting conditions/wavelengths, etc... that is the whole point of PBR is to map these so that materials do act consistently. Check out a couple of the links I posted previously as they discuss this particular point in a couple of the presentations. They also include diagrams comparing Fresnel curves for metal vs rubber, etc...
    Post edited by Joe.Cotter on
    I may try rendering out a displacement map with filter forge to use as tiny fuzz along with it.
    I would think the wax shader would work better then a car shader for hair. Hair has a large sss component.
    edited May 2015
    I'm using the wax for the hair on the last page (hidden in the above render), but the problem is that the maps for this character don't actually have fur. I'm just trying to simulate some sort of fuzz.
    In that case, a velvet shader I would think,
    For giggles, I did the skin with wax too and modified it a bit. I think I like it. o_O
    800 x 640 - 480K
  • Robert FreiseRobert Freise Posts: 4,703
    Nice work
    Aliens meets BladeRunner
    Well we was talking about completely different subject what is Fresnel ior for reflections under Top coat and not about Index of refraction , both are linked but Fresnel ior does not create your objects transparency in this case
    metals are not transparent but still have Fresnel ior reflection
    but your input is good regarding Index of refraction what bend the light
    if hair has sss component we would walk with glowing heads , hair are translucent it does not bounce the light back to eye it pass the light, that why when using car paint that have little metal flakes that simulate cuticles plus a little of translucency will create a great hair shader or fur , thanks to the reflective component in car paint it will more real looking than wax , people use wax for the translucent effect not for sss as that make not sense in hair , the same go for fabric ..
  • AlexLOAlexLO Posts: 193
    "Here's your future, framed in gold!" (name that movie hehe)
    Venus Revisited. View full sized in the gallery
    http://www.daz3d.com/gallery/#images/69286
    1330 x 1995 - 2M
  • jpb06tjpb06t Posts: 272
    Where do I find the DAZ Studio / Iray logo?
  • BeeMKayBeeMKay Posts: 7,019
    edited May 2015
    Here's the current version of my "G2-to-ghost" attempts. It's a slow process, though.
    Does anyone know how I can get rid of the "inner gleaming" of the eyes/mouth?
    837 x 886 - 42K
    Post edited by BeeMKay on
