GENERAL FREEBIE REQUESTS part 3
1272830323335
  • DollyGirl said:
    Chelle the Cat said:
    I'm trying to track down an old Aery Soul/Aeon Soul team freebie release. There was a prop, a wooden door. I have the door, but somehow I lost the textures when I had a hard drive crash. Does anyone know if the four texture packs are available anywhere for download? This is the prop I'm talking about in case people are wondering.
    Chelle I found this about your textures but could not find any of the zips. Siliphiel had a robot.txt file on her domain. Once that is in place Wayback will not download any files from the site.
    [FREEBIE] Wooden Door by Aery Soul's freebie team! - Aery Soul (archive.org)
    Upon reading the forum page I found a reference to the Team and that lead me to opening up the Team Poses 03 file located here:
    web.archive.org/web/20101204211440/http://www.aerysoul.com/free.html
    In the Aery Soul read me is an e-mail address for one of the artists that created the texture files, Scott (Synpainter). You might try and see if you can contact him.
    Thanks Dolly, that's a start at least. I'll see if that gets me anywhere.
  • Eustace ScrubbEustace Scrubb Posts: 2,728
    The door itself is downloadable from the Wayback link @DollyGirl posted (I just did it myself): there's two grass textures and a dirt texture in the ZIP, and that's it.  The door, wall, and metal hardware apparently were set up for procedural shaders.
    I've had the door since it was released. I used to have the four textures that were made for the door as well but the disk I had them saved on was damaged and those are what I was hoping to track down. There was a grunge texture set, one called Bunker, one called Oak/Brass and the last one was Weathered/Patina.  Unfortunately, those were not saved by the Wayback Machine.
    Must've been a different edition of the ZIP saved, then.
  • beachlegsbeachlegs Posts: 524
    Hello I am looking for a Septum Spike for the nose any thing tribal, I have seen the M3D Orc Piercings Set for Genesis 9 I am using Genesis 8.
  • DollyGirlDollyGirl Posts: 2,701
    So this is not a designed piercing but I think if you scale it down you will get the spike look you are after.
    Javelin - 3D Model - ShareCG
    I loaded it into DAZ3D. It came in as three parts so I just parented the tip, Javelin.001, and grip to the javelin. I reduced the size of the javelin to 2.1%. moved the javelin to x: -0.23, y: 165.21, z: 10.89 I then changed the javelin scale X:79.8%, Y: 200%, Z: 200%.
    CoolTuna has spike piercings for M4 here: Cool Tuna Studio > Poser > Poser Freebies They are down at the bottom of the page.
    edited May 2023
    Thank you so much the Javelin would be ideal I just can not get it into Daz Studio for some reason :(
    Beachlegs,
    When you import a dae file you will need to change the type of file you are looking for when file explorer opens up. Location of file type is in the lower right hand corner of the window. I think DAZ defaults to wavefront just click the arrow and other formats will be available to select. If that does not correct your problem I have attached the obj file with the identified changes made. The obj is all combined it is no longer three individual pieces. I used DAZ Studio to create the obj so select DAZ Studio as the identified format that way the spear with come in at the correct place for a default GM8. Original artist applied unrestricted use so I am making this file with the same license.
    You can find the file here: https://www.4shared.com/file/D_g_9qEjge/Septum_Spike.html (Can't seem to upload files any more)
    edited May 2023
    DollyGirl said:
    Beachlegs,
    Thank you so much my friend that was so kind of you, I appreciateyou taking the time..Have a good day :)
    beachlegs said: Thank you so much my friend that was so kind of you, I appreciateyou taking the time..Have a good day :)
    To see your art it is my pleasure. You have a good day as well.
    edited May 2023
    Thank you smiley
  • sfishffrogsfishffrog Posts: 44
    I'm searching for something like this https://www.dreamstime.com/royalty-free-stock-photos-plait-image13259838
    https://depositphotos.com/365049564/stock-photo-attentive-freelancer-looking-papers-infographics.html
    https://depositphotos.com/365049146/stock-photo-brunette-long-haired-businesswoman-medical.html
    - a braid that is like a french braid, really long, that hangs straight down the back (not over the shoulder), that is tight (not wispy), doewsn't start in a ponytail at the top of the head but at the nape of the neck, and thick but not too thick :)  The closest I could find was loreley braid but it is loose at the nape and hangs over the shoulder.
    Those might work. I love renderosity but I have a hard tine getting items to load into DAZ without the installers. But I'll give it a try. thanks.
  • Charlie JudgeCharlie Judge Posts: 13,293
    I use this to create installers for Renerosity items:  https://www.daz3d.com/content-package-assist
    Ooooh!! now that I haven't seen. I'll look into it, thank you. Might solve some issues.
  • Hi does anybody has la femme clone for Genesis 8 female as the tutorial posted in https://www.renderosity.com/forums/threads/2964600/la-femme-clone-for-genesis-8
    and like to shared.
  • Richard HaseltineRichard Haseltine Posts: 108,533
    and like to shared.
    Sharing would need permission from Renderosity, the owners of the La Femme shape.
    ... and Daz3D as the owners of the G8 mesh ;-)
  • Hopefully there is a ceiling panel light like this one out there
    https://gcdn.daz3d.com/p/24359/i/02-i13-bowling-alley-environment-with-poses-daz3d.jpg
    Maybe but figured it'd be faster to simply make one. Obj. file is uploaded to Renderosity, pending approval. Concept is one can move and/or resize it as please, export out a new .obj file. Then import it back in and save it as a Figure/Prop file.
    Oh, thank you. Looking forward to it being approved.
    edited August 2023
    You're welcome, hopefully by the end of the day it'll be available. Sure will be nice if/when we can attach things to posts again.
    update: Download is live now :-)
    Hay! Got an image uploaded :-)
    Post edited by Catherine3678ab on
    The image uploads are very temperamental laugh
    I sent you a PM about 3 days ago, I guess the broken notification system didn't inform you lol
  • Laptop issues plus no, email notifications haven't happened for ages now. Read and replied. Yes.
  • I'm looking for at least one of the following Props:
    • A Video Camera
    • A SLR or DSLR camera
    • Any other Photo video Production paraphernalia.
    • A Video Camera
     https://sharecg.com/v/67916/gallery/11/Poser/HD1000_MiniCam
    https://www.ageofarmour.com/3d/free/video-camera-accessories.php
    Not free but low cost: https://sharecg.com/v/88490/related/11/Poser/KPL-Studio-Set-1
  • Fae3DFae3D Posts: 2,860
    Has anyone made a freebie G9 (preferably female) character skin yet?  I thought I had seen a complete free G9 character with materials, but I can't find it anywhere now.  I need one for the Freebie Contest.
  • Faeryl WomynFaeryl Womyn Posts: 3,741
    Check Renderhub, some of their characters come with textures, just check the free section.
    Thanks for the suggestion!  I have the worst time searching for things on that site.  I looked through the freebies back catalogue quite a bit but all I saw were morphs.  Do you happen to remember a name or a vender name?  I don't think I've seen G9 textures anywhere I've looked (Renderhub, Renderosity, ShareCG).  It's starting to look like I'll have to just use default skins, which wouldn't be the end of the world, but I'd rather use a freebie if I could.
