Luthbel's Paladin HD MMXV Question
SGattonSGatton Posts: 59
Okay, so I'm trying to figure out how to fix this. Maybe it's just because I'm tired, but when I initially load Luthbel's Paladin HD MMXV top into a blank scene, it looks perfect on and around the shoulder plates. However, as soon as I have it "Fit to" a G2M character, there is distortion. I realize it's an issue with weight mapping, but is there a way to stop this from happening without having to edit the weight map? One image is the armor top, not fitted to anything, while the second is fitted to Michael 6. In the areas circled, there is distortion in the mesh after fitting. Surely it can't be so bad as I have to edit the weight mapping just to make this armor look decent on anything but the base G2M?
  • Cris PalominoCris Palomino Posts: 13,023
    This armor was made for G2M, you shouldn't need to do a "fit to". You load the figure and then go to the preset for the armor objects and load, they should go right onto the figure.
  • Richard HaseltineRichard Haseltine Posts: 111,788
    That isn't a weight map issue, since the figure isn't posed. The armour does have custom morphs for M6 so it may be worth reporting this as a possible bug needing tweaking if you see it with just the M6 shape applied to an unposed figure - and if it renders that way (if not it may be connected to the way HD morphs preview).
  • SGattonSGatton Posts: 59
    I know I shouldn't need to "Fit to," but Daz performs that automatically when you load the armor piece. So, whether I use that function manually, or not, it still occurs.
    It does render that way. I'll try it with the HD Detail on the armor turned to 0, and see where it is from there.
    Blast, still works the same, using the default M6 character. The only one this doesn't happen with, is default G2M. The problem seems centered around morphs of the head, which is why I mentioned weight mapping.
    Well, thanks for your help. I guess I'm off to report this as a possible bug.
    Is it both sides or just one?
    It's both sides. It always appears when a head morph is applied, but can also appear when an HD body morph is applied. For the HD body, I can ignore for the most part, since it will almost always be hidden (except that one or two times I want to do something without gloves). However, the moment any head morph is applied for anything from the base G2M figure, instant distortion like seen above. While it is most noticeable in the shoulder plate, it does extend to areas like the collar.
    Select the armor/part in the Scene and then switch to the Parameters tab....click on the little icon that looks like a piece of notebook paper in the corner of the Parameters and choose Show Hidden. Then select Currently Used and see if the head morph is showing up in the Armor...if so, try dialing it back to 0.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,690
    It seems autofollow is enabled for the head which would mean expressions and all would affect it.
    Autofollow is a property of the base figure morphs, not of the fitted items.
    edited May 2015
    Sorry it has taken so long to respond, I had class today for a few hours.
    MJC: Yes, the head morph was appearing on the armor, and dialing it back to 0 certainly removed the distortion. The only downside is the traps then poke through. That is a bit more livable than absolute distortion.
    Post edited by SGatton on
    With the head morph dial, in the armor, you should be able to come up with something in between...a little may be enough to stop the poke through, without too much distortion.
    edited May 2015
    True, but the poke through isn't all that much really. I can try angles that would hide it, but in the end, there are other options, like hiding those few geometric areas.
    Most of what I use things like this for, is top-down tokens for a D&D campaign on roll20. So, it is possible to hide what I need to hide, without losing the overall look of the armor.
    That would certainly work, then.
    All the time I've been using Studio, I never did render my favorite, longest used PC...a Ranger that I started back in 1981. He's older than my 'baby' sister...she was born in '82.
    edited May 2015
    Lord have mercy... my family plays a lot, with my brothers, sister and I raised on it. My dad is able to play his oldest character he started back in AD&D, maybe Basic D&D. He loves it, especially since I can make a nice render for him of it -- a 6'7" human monk...
    I've been trying to use G2M for all the male tokens, and there have been some limitations, most especially armor. I spent a long time trying to convert some armor from M4 or Genesis, so I can use them on G2M, so when this piece came out, my dad turned around and bought it for me -- which he does when he finds a piece that he and I really like.
