loose scarf / collar
thistledownsname
I'm looking for a loose scarf or collar similar to this art piece (I was given the AI picture and am trying to re-make it in daz)
thistledownsname
I went through my runtime and found some items. Not sure if these will help or not. Also the coat looks like one that I am listing below but I could be way off.
Look at the picture of the blouse here: https://www.daz3d.com/dforce-times-out-outfit-for-genesis-8-and-81-females
This is the jacket: https://www.daz3d.com/dforce-giuro-vendetta-hd-for-genesis-8
And an add-on: https://www.daz3d.com/dforce-giuro-vendetta-hd-expansion-pack
At the very least, you might try a kercheif tied around the neck and dForce it. Like done in https://www.daz3d.com/dforce-indian-scarf Not perfect but if no other options show up.
Hopefully others will chime in with their recommendations.
Mary
https://www.daz3d.com/dforce-regency-outfit-for-genesis-8-males (Genesis 8 Male)
https://www.daz3d.com/regency-genesis-2-male (Genesis 2 Male) (better view in https://www.daz3d.com/gentlemen-for-regency-and-expansion, the CG_Necktie.duf is seperate item and not part of CG_Shirt.duf)
https://www.daz3d.com/dforce-signature-style-outfit-for-genesis-8-females (Genesis 8)
https://www.daz3d.com/carhop-for-genesis-female (Genesis)
https://www.daz3d.com/snowman-hd-for-genesis-8-male (Genesis 8 Male)
https://www.daz3d.com/dforce-le-roi-outfit-for-genesis-8-male (Genesis 8 Male)
https://www.daz3d.com/dforce-victorian-gentleman-outfit-for-genesis-8-and-81-males (Genesis 8 Male)
https://www.daz3d.com/dforce-romantic-gentleman-outfit-for-genesis-8-and-81-males (Genesis 8 Male)
https://www.daz3d.com/the-hatter (Michael 4, Hiro 4) (on sale -80% for Daz+)
Steamie for Fancy Punk by Moyra (on Rendo) (Genesis 8, Victoria 8)
These are nicely floofy, but all start too tight to the neck. I did find this which is closer. https://www.daz3d.com/first-date-outfit-for-genesis-3-female-s
I see, so Mary's "dforce-indian-scarf" suggestion is not too far off the mark. Maybe play around with it's scale before simulation.
Or maybe a tie from a Sailor uniform. You could apply your own material to give lace effect.
I don't have any of these so can not advise if the tie is part of the shirt or a separate item:
https://www.daz3d.com/dforce-japanese-sailor-girl-outfit-for-genesis-8-female-s
https://www.daz3d.com/hello-sailor
https://www.daz3d.com/dforce-sailorman-outfit-for-genesis-8-males
https://www.daz3d.com/dforce-navy-sailor-outfit-set-for-genesis-8-and-81-females
In "Sailor Uniform" for Aiko 3, the tie is part of the shirt and not a separate item.
