New Genesis, New Sales Thread: Report Issues Here "Reporting Only"
17374767879100
  • smoke14smoke14 Posts: 271
    Still no promised shader set here angry
    DAZ has to be one the most incompetent group I have ever seen. Absolutely horrendous how many times products are promised at a certain time...free or not...and they fail to follow through on their part of the deal by delivering on time.
    Can't really say I'm surprised...just very disgusted
    My advice to DAZ...stop making promises you obviously cannot manage to keep
  • Robert FreiseRobert Freise Posts: 4,623
    Still not in my Library either
  • barbultbarbult Posts: 26,537
    21 hours overdue. Still nothing.
    edited April 2023
    Forum image uploads seem to be broken again. It just says Uploading forever. This has gone on for at least an hour.
    Edit: Hey, it just finished! I guess I just had to complain to make it work.surprise
    Post edited by barbult on
  • Still waiting on the new Shader too.
  • NathNath Posts: 2,990
    No shader yet either
    Well, at the rate it's going we'll have accumulated all 4 parts of the 2nd free egg & still be waiting for delivery of the 1st one.
    Not good no no
  • Cris PalominoCris Palomino Posts: 12,679
    I got a hold of someone from Daz tonight. He doesn't know the status but will make sure to check first thing in the morning. Apologies, all, that is all the news I have for you atm.
  • SofaCitizenSofaCitizen Posts: 2,137
    edited April 2023
    Charlie Judge said:
    SofaCitizen said:
    FYI it looks like I have the shader in may account now and it's tagged as "Manually Added" so I guess if you don't have it yet then it should be there soon.
    I just checked and it still is not in my account.
    If you search your product library for "pbr metal grill" you should have the 4 eggs plus the shader file as per the screenshot below. If you don't then that isn't good.
    I have no idea how they are adding these items since I don't know what kind of backend they are using for the store - I really don't think they have someone physically looking through the orders or customer accounts one by one and checking to see if that person has all four eggs and then if so adding the qualifying freebie. It would make no sense to run a promotion where they would have to do all that work so it has to be some kind of automation or database query/transaction and therefore it should apply to everyone or no-one at around the same time (or atleast within a short timeframe for a complicated query), then there may be a bit of further delay for any caching after that. For it to be hours or more apart and/or happening for some customers and not others seems a bit odd.
    One thing to note is that there appears to be a typo in the first egg product - it's missing the "e" of Grille. Hence searching for just "pbr metal grill" to find them in the library. Not sure if that has played any part in why there has been a bit of confusion and/or delay with completing the series.
    I'm not sure when it's morningtime in Daz-land but if there is no fix or update after they've been back in the office again for a few hours then I think you can't be blamed for raising a support ticket.
    1934 x 560 - 613K
    Post edited by SofaCitizen on
    Nope...that's not what I get when searching...just the 4 parts & not the actual product.
    EPIC FAIL, DAZ
  • doubledeviantdoubledeviant Posts: 1,345
    It does seem odd, but it's happened before with other Daz promotions. I have all four eggs for the shaders in my library but haven't received the shaders yet. Cris reported it, so Daz should be aware of the issue.
    1080 x 2400 - 189K
    That's part of what is annoying...it has happened before...too many times. That doesn't make it acceptable...it just makes it incredibly aggravating & even more unacceptable.
  • Charlie JudgeCharlie Judge Posts: 13,399
    EPIC FAIL, DAZ
    Same here. I still don't have the downloadable product
  • FareusFareus Posts: 21
    Same - still just the 4 parts for the Pbr Metal Grill, no product. I'm guessing the same will happen with the Gn Lora Hair.
    edited April 2023
    Not sure if it matters, but in my product library, part 4 is spelled "grill", parts 1-3 are spelled "grille". Perhaps this has something to do with them not allocating the product, because it's not seeing all 4 parts with the same spelling?
    Post edited by Fareus on
  • scorpioscorpio Posts: 8,533
    Charlie Judge said:
    EPIC FAIL, DAZ
    Same here - and no official word from Daz - I'll give it the end of the day (uk) and if they aren't in my DIM then, I'll nost likely send in a ticket to return everything I have purchased in the last 30 days. Sorry but Daz should not be allowed to get away with this sort of stuff - its not as if its the first time.
  • Richard HaseltineRichard Haseltine Posts: 109,357
    I would think it was doen on SKU, not name. In any event, we know that a few people have received the shader - it is apparently taking a long time to do all, or there may be a glitch which needs sorting.
  • DanaTADanaTA Posts: 13,361
    If you are correct, that is quite bad.  They should be using the product ID key in a database search, not the name.  The key should be the main indexed column in the database.  Unless they're using BASIC from the late 1970s, the database query should take seconds not minutes or hours.  Unfortunately, I've seen this type of bad tech habit here before.
    Dana
    edited April 2023
    Sorry...doulbe post.
    Richard's post showed after I posted, but the forum software bombed out again.  This happens way too often!
    Post edited by DanaTA on
    The really sad part is that if they don't show up by the end of today, then it's the weekend...and likely 2 more days wait to before anything happens angry
  • xyer0xyer0 Posts: 6,401
    All 4 eggs but no shader. I'm not disappointed though. Disappointment requires a favourable expectation. I, however, fully expected a snafu. I'm an optimist, but I've been trained to expect issues from this store & forum. It's not even frustrating. I just smirk. Not with a bang, but a whimper.
  • joannajoanna Posts: 2,439
    I don't think it does since everyone has the same misspelling, myself included, and I did get the shaders. It's likely as Richard said, long time for the "manually added item" (which we've seen happen in the past—people were gradually getting the promised item), or a glitch that they're working to sort out.
  • JayElJayEl Posts: 41
    Guys, when we finally get these shaders I'm going to take an entire day off work just play with them. They're going on everything. G8's...g9's...toasts...toasters ...v4 eyeballs. Everything's getting metalicized!
  • tsroemitsroemi Posts: 3,527
    yes Do post some of that, will ya?
  • XiousDsXiousDs Posts: 562
    So you are not only an optimist, but a realist as well. lol :)
    Getting late and not looking like they are going to give us any additional offers or the free shader... Pulling the trigger on the cart and getting to bed
  • Bug of today's new header leading to yesterday's sales page is back.
    edited April 2023
    Reported
    edit: should be fixed now.
    Post edited by Cris Palomino on
  • Joe2018Joe2018 Posts: 295
    Bonus Grab Bag says: "Get up to 10 Items for $3.99 each‡ if you’ve purchased any Newly Mad Release in the previous 3 days"
    I bought new releases yesterday and the day before, but only get 5 Items for $3,99. Can that be fixed? Thanks.
  • mcorrmcorr Posts: 1,104
    The Close Out March Madnewss discount can be used how many times?
