West Park is DS4
Testing6790Testing6790 Posts: 1,091
I installed it and CANNOT find it. I checked smart content, and my file hierarchies. I can't find it! It's in an install directory, I've check the actual files and the .objs are there
  • MedzinMedzin Posts: 337
    I find it under
    Environments-->Architecture-->West_Park
    (I don't use the "Smart Content", having deinstalled the Content Manager. I don't need a Windows Service running 24/7 in the background doing who knows what)
  • Testing6790Testing6790 Posts: 1,091
    edited May 2012
    I don't even -have- an Environments folder. I'm using Windows 7, DS4 (the free version). I have Architecture, but nothing but the free content that came with it is there.
    Post edited by Testing6790 on
  • fixmypcmikefixmypcmike Posts: 19,744
    What is the exact path you installed it to? Can you find it outside of DS?
    edited May 2012
    I think the problem may be that you used the Poser installer instead of the DS installer.
    The Poser installer will place them in "Runtime/Libraries/Character/" and you will have to select "Poser Formats" to find that folder
    There are 6 installers for West park, 3 for DS and 3 for Poser
    For DS, the files are:
    11912_2_ds_WestPark_2.exe
    11912_3_ds_WestPark_3.exe
    11912_8_ds_WestPark_8.exe
    Post edited by Medzin on
    I used WestPark_1 and _2 :(
    Then you have an incomplete install even for Poser.
    You should request a reset of your download and get the 3 DS installers.
    Actually, I'm only posting this picture to see if I can attach an image yet.
    This is what you should see on a proper DS install. BTW, there is no light set in the Poser version
    334 x 600 - 52K
  • grpruettgrpruett Posts: 255
    I had trouble with this too with most of the West Park items. I gave up on trying to load it into daz runtime and redirected the installation to my Poser 8 runtime. It worked once I had it loaded in the Poser 8 runtime.
    I still don't know why it wouldn't install correctly under Daz.
    Maybe you were using the wrong installers also.
    If it worked under Poser, you certainly were not using a DS installer
  • KeryaKerya Posts: 10,943
    West Park was updated - everybody resetting and downloading now will get less files.
  • JaderailJaderail Posts: 0
    Unless a item has MetaData which most Westpark items do not have they will be found in the Content Library Tab. Not the Smart Content Tab.
