rendered skin low res + render too fast
lumiasart
hey everyone!
started a new work and decided it was time to try and "fix" my character's skin render. For some reason it always looks low res compard to the rest of the textures (clothes, etc...)
I've just spent the good portion of 2h researching how to fix this but all I see is "denoiser is bad" and "change your render settings". Usually my render settings are:
Render Mode = Photoreal
Max Samples = 10000
Max Time = 0
Rendering Quality = 3
Rendering Converged Ratio = 100%
which I actually got from this forum since my render was waaayy too fast and crap. Anyway... the lighting used is https://www.daz3d.com/iradiance-crystal--sparkle-rich-hdri-for-iray which I suspect is partly cusplable but it also ahappens with other lighting so... *shrug*
thanks for any help you can give! <3
EDIT
after opening photoshop I noticed that the black textures are also the same... :(
EDIT 2:
I changed my render settings and even with 1500 max samples it renders in 30 minutes... is this the problem? I can't make it render longer so it's not finished and it looks low res?
What skin are you using?
I'm using Reine by Crocodile Liu https://www.daz3d.com/co-reine-and-co-reine-hair-for-genesis-8-females
I forgot to post the picture *faceplam* it's now posted.
You can disable rendering quality and that will not stop the rendering anymore
Sorry for not getting back sooner. I had a friend who has that character check it out to see if it had any special properties that would make it take longer to render. Glad you got it sorted out.
